EVT 60 volt mod
Just installed the 60 volt mod from Electric Motorsport on my EVT 4000e. No magic smoke escaped, Woo-Hoo!
Best. Upgrade. Ever.
I only had time for a short test ride, and the forecast calls for rain tomorrow, so I won't have any objective GPS data until Sunday. Scooter speedo showed 42 MPH at top speed. Better acceleration -- Economy mode is now peppier than 48 volt Power mode. Better hill climbing. I hardly notice the extra battery weight when riding. I am a VERY happy camper.
I installed the 60 volt mod this afternoon without removing the body plastics. Easier than installing PowerCheqs. Now the bike performs like I always expected it to. I should be able to keep up with my wife's Honda Metropolitan now. I did 10 miles of fast take off, full power, stop and go riding and it was still on the top green LED when I got home. That should mean I've got a good bit more range with that extra EB-50.
I'll post more when I get a chance to gather some good numbers with the GPS.
I have to get 60 volts into my RazorPR200, lol she should be a rocket then!
good job, glad to hear the magig electric smoke genie that steals your hard earned money stayed in the bike...lol
I hate it when he peaks his head out of my bikes, it allways costs me about $150 every time I rub that lamp!
could you post a vid on youtube?
good luck and be safe
I will shake my fist at the rain here tomorrow, lol good for my plants not good for me and my need to keep dry. ya dig? lol
Mike M
How hot is the motor getting? *dreams of EVT Z20 on a 72v mod
Anyone got one they might want to sell?
My KZ750 Project: here E.T.A. 1 mo
Pictures please ! And did you install both chargers on the bike ?
Craig Uyeda == Deafscooter is Here...
I read your modified the EVT 4000 Scooter with 60 Volts
and stilll problem on your HUB Motor will burn out brush!!!
there only 42 Mph top on 60 Volts total batteries powered?
Crusher300,
If you have some exposed motor wiring, can you take a voltage measurement while riding at top speed? Lemmiwinks said his scooter toped out a little bit slower at ~31 mph after the Asian controller mod.
Crusher;
Thanks for the kind words, and nice job on the photos! I hope that explains it to everyone.
I was a little disappointed to see only 34 mph. I've never tested with a GPS, just guestimating the true speed. If at all possible, could you try the same thing with a very light rider? I'd love to see if there is a difference. I ran my Lepton at 60 volts, and all it did was go slower due to the extra weight.
Two ways you can measure motor voltage. Intercept it at the black Andersons (below the red ones) is one way (grey will also mate with black), or use insulation piercing probes. A peak reading (min/max) meter will save you from looking at all if you've got one. I can do it in the shop, but it might be a while as we repaired and returned that torn down 4000. The next one that comes in, I'll give it a try - I'd like to see voltage vs. current on a flat road. I wish there was an electronic tap for the speed; photo tachs don't cut it on the road.
Remember to watch the motor temp., especially on hills. Not only the brushes, but the winding epoxy can burn/melt too (as I know from personal experience). Harbor Freight has an IR thermometer for $7 - $10 that's probably OK - I'm going to try one. May not be super accurate, but fine for comparative measurements.
Patrick
Hi Patrick
How did manage to power 60 volt to scooter without doing any damage ? , and was 60 V going directly to the motor ( measured at the terminal , not connectors )?
I also have a Lepton-e , and somewhat suprise to find that we have a brushe type motor ,had assumed that we had a brushless motor.
You appear to be very familar with the scooter , how long have you had it ?. did you make or get a wiring diagram showing controler , motor , batteries connection etc .if so could you make available .
Have been unable to get any technical assistance from the factory , have you had any luck with them ?
Have some Nickel-Zinc pack that I been running for the past months , had very good result as far as charge , and discharge goes with new
BMS on the cells .
What power pack are you running your scooter with ? have you keep track of performance and cycle life ?
Do you have any idea how many Lepton-e been sold in the USA ?
Regards
Andre
Hi Andre:
(FYI - this post is all about the Lepton, not the EVT - if anybody wants more info, let's start a new thread)
For the 60 volts, I just stuck an extra EB-50 under the seat and wired it in series. I knew the controller could take it, as "Error 1" indicates over 70 volts. While the bike ran fine, (albeit slowly) it did hit the Error 1 everytime I used regen while going fast. No other problems were noticed.
This was wired to the controller, not the motor. The motor is brushless, not brushed. IMO, the Lepton has the most elegant controller of any small EV - wish they weren't so slow. I've got a few, and have been working on them about a year. I know them quite well, and would be happy to give tech support if anyone is interested. I don't get any info from the factory; they are end-of-life. I would guess 500 to a thousand sold in US. I have no wiring diagrams per se, but I know what most of the wires do, and the logic of the wiring.
I run both B&B Eb-50s (that's the normal 20 hour rating) and Hawker EP-42s (that's a 10 hour rating). I don't really measure cycle life, etc - I am just fanatic about battery care, and get new batts when the range hits about half (about 3000 - 4000 miles). Also careful not to discharge them more than about 50% (except rarely).
The Evercells can be excellent. They are lighter and make the bike accelerate better, but not as good at high current draw (500 foot elevation gain). I've only dealt with all the leftovers in the shop. But my experience with them has been up and down. In fact, I think I blew up a pack recently - but they don't fit my application for the money. I've toyed with the idea of a Lithium pack (will test one soon) - but don't think I'll buy one. Why drop all the $$$ when the 30 mile range fits 95% of my need? The other 5% is just for fun anyway.
Best,
Patrick
This is direct from the manufacturers website:
http://www.evt.com.tw/html/product_evt/english/index.htm
1. Over-heat Protection :
When the temperature reaches to the limit, the system shall supply only half power, or cut off the power .
Whether this means there is a temp sensor in the motor itself, or only in the controller, is not clear.
Amanda
What a great modification!!!!!
Thank you for sharing how it's made. Thank you Crusher. Thank you Electric Motorsport.
I put it together yesterday. It took me 2 hours but I have not yet connected any Powercheqs and the additional charger is temporarily connected.
It was not to difficult to find the correct wire to cut, but I'm adding a picture of how it looks on my bike. (It's the red one in the middle.)
After I cut the wire I measured which end that was currently feed with + 48 V,
that's the wire that we do not need any more. The other one is were you need to
crimp the connector for the new + 48 V feed.
This how the the connectors and the additional cables for PowerCheq and Charger looks.
I love the extra speed I get and I'm not ever going to convert back.
Take care
Magnus
Stockholm, Sweden
`mbqmbq,
Welcome to our V is for Voltage Community, great pictures, thanks for sharing.
Stleride
Moderator Team Captain
Moderators are dedicated volunteer V Team members who help keep your V Forums running smoothly and provide Forum Support.
The fourth Powercheq could help to share the load of the DC-DC converter.
I may not be much help but I hope it will get me some additional miles ;-)
If the PowerCheqs could give more than 2 amps (according to spec)
the DC-DC converter would not be needed. Just hook up one battery
and it will be fed from the others.
/Magnus
mbqmbq,
I thought the same as you so I contacted the PowerCheq folks and they advised me against doing this. They said it could cause more battery problems rather than helping. I would recommend using a DC to DC converter as they suggested to me. Here is a data sheet and wiring diagram for a very good DC to DC converter.
Lucent JW030C1-M DC-DC Power Module Data Sheet (36vdc to 75vdc input @ 30-watts)
Chas S.
My Bicycle Pages
The headlight is 35 W so a 30 W DC/DC is not enough. Let's say it's 60 W and that would result in a current of 5 A. The PowerCheqs would need to be rated at 7 A to be able to handle the DC/DC and handle the battery "equalization". The business case for this type of PowerCheq would be based on replacing the DC/DC (less heat consumption/better efficency) and battery equalizer. It would of course be a more expensive device.
/Magnus
PS I'm adding one more picture. The female connector looks so ugly so I didn't feel like showing it here, but I think it can be useful for others to see how the wire is cut. (It was not only the red shrink tubing that shrunk. The blue part of the connector did so too. This female connector is only used when converting back to 48 V)
Just want to point out several errors in this posting and elsewhere in the thread.
The controller is a pulse width modulated controller. It does not decrease voltage, it just
turns the voltage on and off rapidly. That decreases POWER.
That means with a 60volt battery, 60 volt pulses are reaching the motor (and brushes). Because the US
controller maximum pulse length is 80% on time, one might think that the total POWER (volts x amps x time on) reaching the motor
with 60volts would be the same as with the asian controller and 48v. But you'd be wrong.
If the motor resistance (or back EMF) is constant (probably isn't, but close), 60 volts is 20% higher
voltage and 20% higher current, which is 44% higher power. The 80% duty cycle of the US controller reduces
the actual power increase to 15% (over an asian 100% controller with 48v battery).
The motor may or may not overheat with 15% more power than the asian version.
The brushes may be just fine with 60 volts, I don't know. I'm not saying
either will fail, just that both are increased.
Actually it does decrease the voltage because it has a lot of capacitors and a freewheeling diode to allow the current to flow during the off part of the cycle. It functions like a variable DC-DC converter.
However, as you mention the % of on does not have a relationship to voltage, but power.
I will try to figure out whats going on by going back to basics. Who said the American controller only goes a max of 80% on time and how did they establish that? If that is correct than:
Lets say you took the controller out, and put in a switch. If you switch it on while running 48v than 1p power will flow. Because of the relationship of V = IR the maximum power that can flow is a function of the square of the change in voltage. 60v/48v = 1.25 * 1.25 = 1.56p will now flow on 60v.
The maximum power that will flow at 80% on time at 60v is 1.56 times higher than the maximum power that will flow at 80% on time at 48v.
Now if you go back to 48v and the switch and decide to leave the switch on for 80% of the time, than you will get 80% of the max power on 48v or .8p. But if you leave it on for 100% of the time you are increasing the power by 25% of what it was when you had the switch on for 80% of the time because 100/80 = 1.25.
This means that the Asian controller should increase the power by 25%, while the 60v mod to the American controller should increase the power by 56%. And the 60v mod to the American controller should offer about a 25% increase in power (1.56/1.25) vs. the Asian controller on 48v.
` andrew,
Sorry for this off topic post, can you chime in on Has anyone modified a China Brushless Hub Motor Controller to increase performance?
Peace Out,
Gman
I got a question regarding the charger and if it's still room to use the PowerCheqs.
I'm adding another picture to shows the Ctek charger and the PowerCheqs.
/Magnus
Hi
A question for Crusher - hope you read this!
Just wondering if you could give us an update on your 60v EVT?
I'm interested to hear if its still performing well after six months or so...
Just wondering, Is there any way to do this MOD to my EVT 168 equinox? I have no room at all under the seat for another battery. I do have a rear lockbox.
Has anyone tried to do this to a 168? If so please do tell how you got on.
Andrew,
the motor gets hot, but not alarmingly so. That said, it also got quite hot after a good ride at 48 volts. I pretty much max out the weight limit for the stock bike all by myself. With the extra EB-50 in there I'm sure it's now overweight. Probably wouldn't be so hot with a smaller rider. I don't have a good way to get accurate temperature measurements, but I touched the motor housing just after my ride yesterday and I could hold my finger there for a second or two, but probably would have got a blister if I kept it there much longer. That said, the temperature increase seemed pretty much proportional to the speed boost and more aggressive acceleration. I plan on going easy on long uphill stretches, but frankly I'm not too worried about increased heat or motor wear. Here's why:
Over on the 'EVT "asian" Controller' thread Patrick posted oscilloscope data for the EVT controller output. This showed that the US version of the EVT controller limits the voltage to the motor to average about 80% of the pack voltage. If the pack voltage is increased to 60 volts, then 80% is about 48 volts, exactly what the motor is rated for! That's why this mod works so well. When I picked up the 60 volt harness and battery, Patrick told me that they had done about a dozen of these mods to customer bikes and none had come back with problems. This also suggests that if you replaced the stock EVT controller with something carefully tuned and optimized you could get performance similar to the 60 volt mod with a 48 volt pack. The thing is the 60 volt mod is easier and cheaper than replacing the controller.
-Crusher300
Silver EVT 4000e (60 volt) San Mateo, CA
-Crusher300
