scooter wil not run
12 posts / 0 new
al7777
al7777's picture
scooter wil not run
I ENSTALLED 6 NEW BATTERIES AND WHEN I TWIST THE THROTLE IT JERKS FORWARD ANY HELP.....
Spaceangel
Last seen: 4 days 23 hours ago
Re: scooter wil not run
Enstalled? How far forward does it go? When my battery pack was charged or so I thought it did that for a foot then died till I did it again. One of my new batteries was dead dead. It charged up in short time and died just as fast. I load tested every one and found two more that were weak and replaced the whole pack with matching load tested batteries. There is a bank of capacitors in the black box and it can go for a second or two on just charge of capacitors. I guess some black boxes are aluminum so I should say controller. I like to test every battery with a small load tester frum? Harbor Freight. It does 50 amps and that seems good for most scooters.
Some times a brake switch can cause similar problems too. Also if you have too much voltage it can go into shutdown also like when I did 48 volt on my TANK scooter and did 60 volts. I waited till lights pulled voltage down to 64 point something and it went forwards. Maybe if you installed them it might go better~er?
KB1UKU
al7777
al7777's picture
thank you very much for the info im new to this and it was very helpful....
al7777
al7777's picture
batteries
ok your batteries are fully charged you plug in the charger the charger lite should turn green but it does not is there a charger problem..thanks alex
my skype adress is alexander.sweeney [at] gmail.com
nyy0604
Last seen: 13 years 4 weeks ago
al777,are you bike original 6 battery? if you try to modify from 3/4 to 6, you need to change a controller of 72V which is really rear. 60V is available I know.
Spaceangel
Try going back to 5 battery pack? All controllers have under and over voltage set ups in controller.
KB1UKU
al7777
al7777's picture
thank you for the reply i have 48 volts and 800 watt motor im new to this...alex
al7777
al7777's picture
i have 48 volts and a 800 watt motor ..yes it has 6 newe batteries i would not know to set the controller
nyy0604
generally you should not change the voltage. If your original is 48V,you can only put 4 batteries in. The controller and motor and powermeter are all the same voltage. It will be very complicate to add more battery in the bike. I would suggest you keep the original way.If you really want more range you can use bigger battery like 20AH if you can find a place to put.
al7777
al7777's picture
yes i have 20amps. were can i learn about controllers and voltage..thanks alex
Spaceangel
I had a 2003 TANK and it did the Same thing. I went to 60 volt and it apeared to now work. I turned on lights and aftera hour the pack voltage went low enuff vs your enstalled and rode it till bike dealer blew it up some how. The cover Joltage circuit kept if from going. I gave me 2 miles more range but wasted my time killing battery pack for an hour. I ordred a 60 volt controller and it worked fine but am too lazy to fit it in under trunk area so it is in back of garage till i get more fre time.
Bike controller likw AC or variable frequency controllers have under and ovver voltage stuph billed in?
KB1UKU
al7777
al7777's picture
thanks rusty for the info...alex
