I am upgrading my Lashout and I need to know how to mount the controller, all the photos I see have it mounted on the rear rack support but they are never detailed enough for me to see how they mounted them. Here is my photo
and here is a photo of a modified one with the controller somehow magically mounted on I could really use the help, thanks.
Need Help!
Thu, 01/27/2011 - 10:29
#1
Need Help!
- Juli76
- xovacharging
- stuuno
- marce002
- Heiwarsot
You could try using heavy duty industrial strength Velcro. Just make sure that you pull it tight enough to make sure there is no sag. you'd need to get the kind that bonds to metal and make sure you thoroughly clean the area before you stick it on there. I did this inside my battery bag to keep stuff from sliding around. I originally had my controller mounted to my battery which sits in the middle of my frame. Velcro works great.
