Bionx needs power going downhill?
2 posts / 0 new
Aconite
I just had my 350W motor replaced under warranty. The new motor is showing some odd behavior that my old motor did not.
The new motor I noticed has a stronger regen, when is nice. Same console, and I had the regen turned up as high as it would go (40).
However, going down hill, starting around 37-40 km/h, the console starts to show that I am using power. Even if I set the console to 0 (no assistance).
Why would the console show that I am using power going downhill ... it is not showing that I recharging the battery (left side of meter) but I am using power (right side of console)? It gets up as high as around 3 or 4 bars.
Aconite
Re: Bionx needs power going downhill?
Nobody replied, but I thought I would leave a note just in case someobody is searching for the same answer.
I contacted Bionx. They told me that I only needed a firmware upgrade. When my dealer replaced my motor, they never did a firmware upgrade (because he does not have the updater device).
I found a shop that has the Bionx updater and had my firmware updated.
Problem solved.
