How to Live Well Without Owning a Car Save Money, Breathe Easier, and Get More Mileage Out of Life
Dc motor help
2 replies [Last post]
How would i know if the Dc motor and how would i be able to test it.Since im doing my senior project on building a hydroeletric mini scale dam.I was thinking that i should use a dc motor with a wheel but the problem is how do i know if the motor works?
Re: Dc motor help
Sort of bad spelling? hydroeletic? Are you using a permanent magnet motor? What voltage is motor? Are you using a turbine wheel? paddle wheel? Hydraulic screw? Are you using it as a motor and generator?
jeGra Project
http://home.comcast.net/~russell239/
Rusty
Re: Dc motor help
I will be using a Turbine Wheel,Permanent Magnet motor and i will be using it as a generator.I just dont know how many volts yet.Where would i be able to find a permanent magnet motor.I mean if i use it as a generator and water flows through the wheel it would generate Electricity?
Short URL
Customize This
