BionX motor failure with 48Volt battery
4 replies [Last post]
hmnavarro
Hi, I'm new to the forum and I address you all in case someone can help me solve my problem, I bought an electric motor kit for my bike in the U.S. , with reference PL350 HT SL XL 48Volt. Which worked well the first month, but since time began to show an error on the screen (wrench) but it worked normal until one day the battery will not charge and from there I have my kit died ...... I wonder if any of you could help me or guide me in what I can do ......
Uploaded with ImageShack.us
Tonyxhb
Re: BionX motor failure with 48Volt battery
did you check your battery? two things may fail, one is the batter, another is the controller.
Jhorrick
Hi
I have a 48V system also and I am waiting for a updated battery from Bionx which is suppose to take care of the no charge issue and other things I guess. I am waiting for my dealer to get it so I can try it out. It is taking forever since the recall was announced in december to my dealer. The battery might take care of your symbol. Contact your dealer about a replacement battery. This will be my second battery since I recieved the system in the end of May 2011. Not a real confidence builder in the battery so far.
J Horrick
bxcycleman
I bought 2 systems. Both consoles failed, then one battery, then one hub motor, then the other hub motor, finally the special order wheel had metal shards which were never cleaned out, and kept puncturing tubes. The warranty was good for awhile. So, after everything finally gave out I wrote BionX US rep, Mr. Coulombe.
No answer yet. I just feel it should work. Every other electronic thing I own works, so why not BionX?
And you're right. It sure doesn't build confidence. It's such a good idea too. Too bad the stuff is so quirky.
Briggs31
Check the battery first
style="display:block"
data-ad-client="ca-pub-2401070691062219"
data-ad-slot="2079401426"
data-ad-format="auto">
High Voltage: The Fast Track to Plug In the Auto Industry A behind-the-scenes look at the robustly competitive race to dominate the market for electric cars.
Free guide to electric car charging extension cords We sometimes need to lengthen the charging cord, and need to know how to do so safely.
Who Killed the Electric Car? Essential documentary explaining what happened the last time electric cars were killed
  • LiFePO4 Battery
  • teemumeena
  • carlos1984
  • Francie Cowles
  • evt4000_94566
Customize This
