E-max 110 S changing back tire very easy to do
today my back tire was flat.
Put the Emax on the main stand, use the necessary screw driver and take out about 15 screws. Watch out, don't take out the 3 screws who where deeper, they hold the motor together. Now you can take away the outer ring. The tube comes out and in my case I fixed it with a patch (normally used for bicycles). I mounted everything together and it works fine.
Greets to All
