oil leak at rear hub
I noticed oil over the rim on the rear wheel the other day and found a leak coming from the area between the planetary gear set and the electric motor. I dissembled and found the seal runner on the back of the gear set was spinning on the hub of the motor so the oil seal had not failed. The oil was coming out under the seal runner I clean the area and loctited the seal runner back into postion fitted a new seal, fresh oil as all is well. This happened at 35000 klms If any one needs to purchase a new seal for the job the part no is tc821008 regards rob
I had this experience too, but after I did the gearbox modification. When I took it back apart to see why it was leaking I didn't see any tears in the seals, so I just put it back together. I think I had just overfilled it. Did the new seal stop the leak? Where did you order the seal from? Vectrix never answers my emails!
Does anyone know the sleeve size ?
I have three of these available at cost. I bought 4 of them, one for me and three to avoid getting stung on a minimum order charge... about £10 each, they worked out at, including shipping...
oil seal was avail from bsc motion technology in adelaide but it wasn't the seal that had failed it was the sleeve that the seal runs on I just put a new seal in while I had it apart the part no denotes the size 100x 82x8 mm wide
rob white
