Currie Electro Drive 1000W Motor question
Hi all.
I have a couple of these Currie 1000W Electro Drive motors. They came from the EZip 1000.
They turn CCW as mounted on the EZIP.
I would like to use one of them in reverse (CW) in a bicycle with a CVT, and it has to turn CW to work.
Do any of you know if the brushes are advanced or are zero degree timing? I have not been able to find out from searching online, and before I try to test it out myself I was hoping someone here would already know.
Thanks in advance! (pun intended) ;)
Newton
