Wiring, Throttle,Controller,Motor???
Hello,
I have a Schwinn 1000 Watt motor and a Kelly KDS 48Volt 100Amp controller also a Magura 48Volt Throttle. All mounted to Bike.Batteries 4/ 12 Volt 22Amp connected in a series and in a hand made case. Ready to wire well I tried to wire but can not get it to work! HELP please.
What or where am I going wrong?
Put these links on so you could see what I have and am working with. Also some wiring info in the Attachments.
Links
Motor = http://www.monsterscooterparts.com/36vo10mo.html
Controller = http://kellycontroller.com/kds48100100a24v-48v-mini-brushed-controller-p-284.html
Throttle = http://tncscooters.com/index.php?route=product/product&path=65_79_85&product_id=75
| Attachment | Size |
| KDS simple wiring diagram.pdf | 12.67 KB |
| TNC Scooters Wiring Dia. For Twist Throttle Cable with 48 Volt LED Meter.doc | 21 KB |
