Bionx 250 not charging
My Bionx 250 LI is a few months old with very little use. It has not yet run dead but when it is unwilling to charge. It shows 1 bar on the screen. When I try to charge the light goes from yellow to green in about 2 seconds. I tied the battery recovery with no luck. I did notice that over the past few weeks while not in use it would on occasion beep in the garage. Perhaps it was trying to tell me something? Any suggestions as to what might be a home fix at this point or do I need to ship it to the dealer (out of state)?
Yes, the beeping in the garage meant it needed to be charged. Now the voltage is probably too low for the charger to recognize it properly.
One solution to this I have seen (but not tried personally) is actually to get the voltage up enough to allow the charger to work properly. If you can get the system to power up at all, put it in generate mode (opposite of assist) and hand crank it or pedal it on a trainer -- for a while -- to try and boost the level of charge in the battery to the point where your charger will recognize it. I've seen a couple of reports of this working well.
Charlie
If you are in the USA, check that your battery charger is set for 115v. There is a switch at one end of the charger that allows the user to change the input voltage from 115v to 230v. Your switch may be in the wrong position and will not initiate the charge cycle. If this is the case, use a paperclip or tip of a pen to slide the switch down to the 115v position. Hope that's all it is.
