Three swollen batteries due to over charging for 72v hub motor led to intermittent slow power/batteries or controller
Hi all,
I have a Chinese electric scooter that I got running (YAY) with self made, brain racking wire diagram diagnostics, and the help of an English guy and his new controller (Thank you for your help btw).
Immediately afterward I set up the "smart" charger to do it's job overnight and woke up to go to work. I worked till 230, got home @ 3pm, opened the garage and found three of the six 12v batteries swollen and smoking from the long charge. The supposedly "smart" charger was dumb indeed and did not stop charging for basically 24 hrs. (red light still on)...AAUGH!! I put out my cigarette immediately, disconnected the thing, let it cool a day and go to run the thing and it won't go well. With slow throttle it spins the wheel with little power and can hear the halls doing their job, but full throttle the wheel spins in short spurts of VERY little power. I checked the throttle for juice going in (5v right) and about 4.8/4v coming out at full throttle and find 4.8 going in but only 2.2 coming out.
I am assuming that the batteries are gone...DUH...and need to be replaced
Questions:
1. Must I replace all 6 batteries or can I get by with replacing just the 3 swollen ones (their freakishly expensive and I have little $$$)?
2. Where can I get inexpensive sealed lead acid batteries (or just batteries) from quick in San Diego?
3. Is the throttle bad or are my test results just the symptom of the bad batteries?
4. Why didn't the so called "smart" charger turn off like it was supposed to, is this common in a 6 battery bank (they all have the same charge btw)
I'd appreciate any advice from any of you eride guru's
Oil resiliant,
Steve
I can only try and answer one question for sure and I do have experience in that area.
Questions:
When I got my first Chinese scooter the charger did what you descibed and over charged them and I replace the fat batteries and left the other three. I ordered a new regulated charger and in a very short time the new ones failed and I went back to Interstate and they said you have to replace the whole pack and wouldn't warranty the bad "new" batteries. I ordered a new pack and in two or three charge cycles got in perfect balance. Reason is ampere hour has to be the same in series string. An old pack battery group will be out of whack and less AH capacity. You can put in a few good batteries to see if scooter can run a OK but that is about it.
I have a about 60 / 40 ratio of getting a good charger made in China. When I get a charger from TNC in Tenn, USA they smoke test all of them that they sell. If they let the smoke out of them they deal with it. If it is able to keep the smoke in and it charges the pack then it is good for re-sale. I don't know of battery sellers in California but most scooter use an alarm type of battery like a 20 AH EVX12200 and Yuasa 17 AH types.Throttle? Don't know - too many variables.
So I would go with replace the pack and test each one for a week and make sure they are good with a new charger. Believe me they will self balance if same run and date code. Charger must be C/5 to C/2 or 3 for good charge time or no less than C/10. I hope you get on the road soon on electric. Let us know AH of pack voltage total, and charger manufacture.
I tried hooking up the charger to the scoot and the same results applied
