Warranty Problem
My warranty on my xb-610 is about to run out and I bought my bike at GreenMax Distributors in Tacoma, WA.
I called and message says they are closed.
I filled out a Xtreem Scooter report ticket.........No Reply.
Any advise on what I should do?
I think the controller is bad (I turn key on and Motor runs without using throtle).
Also, the lock on the seat goes round an round and can't open the seat.
I have the same problem on the glove compartment lock.
Most sellers will refer you to here:
http://www.x-tremescooters.com/services/customer_service.html
This is the main dealer of these bikes in USA.
I think you might have a stuck throttle cable. Put on rear legs, and try revving the throttle a bit to see if it comes loose.
Well my scooters got hit by a Bus and was totaled!
No "damage" to yourself??? A bus - yikes!!!
Good to hear that you are O.K. :-) But sad for the scooter...
Thanks for the reply:
(I think you might have a stuck throttle cable. Put on rear legs, and try revving the throttle a bit to see if it comes loose.)
I checked that and the throttle moves good.
I disconnected the throttle wire from the controller.
The motor still moves when I turn the key on
