Problem - not sure where it is from
No replies
Jonathanm
Well I have an issue - at times disabling...periodically I get large fluctuations in the voltage display on the speedo (Lairds Software). When it drops to below 100V the bike obviously stops. Then it comes back and all is good for a while. When this is happening, when regenerating the voltage can go over 150V and then just as quickly under acceleration go below 100V.
This issue started when I abruptly cut the "cruise control" one day. I reset the plugs under the front fender and that seemed to fix things but it still happens periodically.
So I cannot work out if it a MC problem or a cell that is shot? I still have Ni Hy cells and nearly 40K km. Have not been here for a while - happy to see a few old faces....
Jonathan
style="display:block"
data-ad-client="ca-pub-2401070691062219"
data-ad-slot="2079401426"
data-ad-format="auto">
Who Killed the Electric Car? Essential documentary explaining what happened the last time electric cars were killed
V3 Cycle Analyst for Electric Bikes Ebike Display The Cycle Analyst V3 dashboard with speedometer sensor and magnet is a great addition to any Ebike
  • michealmottiff
  • BettyPRedden
  • erik550c
  • Wheel Gears
  • SimonK
Customize This
