Charging Nissan leaf cells with LiFePO4 Charger
5 replies [Last post]
Phildiann Healey
Phildiann Healey's picture
I have recently added Nissan leaf cells to an ERIDER 8000W scooter. I am using a ZEVA BMS to monitor charging of 10 Nissan leaf batteries (20 cells x 4.2V = 84V HVC) using a charger designed for 24 x 3.65V = 87.6V HVC Lithium Iron Phosphate cells. The charger constantly charges at 20A or C/3 for the 60 AH Nissan cells until the end of charge signal from the BMS trips the relay and stops the charger. Is it OK to charge at full current right up to the 4.2V high voltage cutoff ?. Most lithium battery chargers appear to reduce current for the last 10-15% of the charging process. I am limiting the cells to 4.1V at present until I get this sorted out but would like to get the last 10-15% of battery capacity.
Re: Charging Nissan leaf cells with LiFePO4 Charger
As you already noted your LiFePO4 charger would switch from CC to CV stage when the batteriy reaches 87.6V. But with the 10 Leaf modules you can never reach that voltage as your BMS shuts off charging when the battery reaches only 84V. Your charger would have to be tuned down to 84V for it to switch to CV stage, if that is possible at all...
QvR vR one: a Swiss package of pure understatement - innocent and to some eyes (from some angles) exceedingly ugly looks, but with raw and hardly containable electron power up to real 95 to 100km/h! And a literally rock-hard suspension due to a carrying capacity of twice it's unladen weight... Now converted to more controllable and efficient brushless motor and vector-contoller.
E-Sprit Fury (basis is the Erider Thunder 5000) since May 03, 2011. Highly moded - but now in active retirement
Phildiann Healey
Apparently when in the Nissan Leaf, the cells are only charged to 4.1V to maximise battery life. I don't know if this is with CC and then CV charging but I suspect it is. This is about 90% of full charge.
When I charge at CC to 4.1V am I achieving 90% of full charge. I suspect not as I have CC charged a couple of times to 4.15V and this gives 10% extra capacity. My question is if I CC charge to 4.2V will the batteries still be not fully charged and likely to last longer?. My charger is not adjustible so I can't reduce HVC.
you do lose a little capacity charging CC to 4.1v as opposed to cc-cv to 4.1v
you could get around that by just doing cc to 4.15v, or accepting the slightly lower capacity
when the highest cell reaches 4.1v, what's the lowest cell voltage?
2007 Vectrix, modified with 42 x Thundersky 60Ah
Vectrix 60Ah Lithium Tyres Fuel Registration Insurance cycle analyst 2 x TC Charger & MC
conversion
Spent so far: $5800 + $7000 + $2040 + $1200 + $425 + $800 + $140 + $3000
Cost to do it again: $1000 + $3800 + $2040 + $1200 + $425 + $800 + $140 + $1500 (lasts longer)
Cost for a Petrol bike:$6000 + + $1440 + $7560 + $1000 + $1600 + $4000 servicing
Total spent: $20405
Total to do again: $10905
Total to have used a petrol bike: $21600
Total distance travelled so far: 102'120km
Other vehicles:
2008 Mazda 2 conversion
2009 Blade Electron
1997 Prius - plugin hybrid mod
Phildiann Healey
When highest cell reaches 4.1 volts lowest cell is close say 4.07-4.08.
Phildiann Healey
I have hacked the charger as detailed in the post:
http://www.diyelectriccar.com/forums/showthread.php/elcon-charger-voltage-adjust-51100.html
and managed to reduce HVC to about 84V. Excellent.
style="display:block"
data-ad-client="ca-pub-2401070691062219"
data-ad-slot="2079401426"
data-ad-format="auto">
Free guide to buying Electric Car or Motorcycle charging stations Learn how to choose the best charging station for your needs.
  • mcent
  • vwir
  • Monstarr
  • PowerPuller
  • julie78787
Customize This
