Ok disappearing
4 posts / 0 new
Vortex
Ok disappearing
Sometimes when i'm riding in my vectrix, the 'ok' disappears from the display.. Any idea??
Last seen: 10 months 4 weeks ago
Re: Ok disappearing
Maybe your Vectrix disapproves of your driving style sometimes and lets you know by withdrawing its OK :-)
boeingpilot
Re: Ok disappearing
Check you kick stand switch. I'd bet either the stand is bouncing or the switch is dirty. It's a safety thing. If the bike thinks the kick stand is down it cancels the OK
2015 Tesla S90D
1983 Lambretta Lynx
1980 Vespa P200
Vortex
Re: Ok disappearing
I don't think so.. normally this problem only give me when i do long way..
I contact Matteo, and he told me that:
"Th GO dissapearing can be CAN BUS noise and is generated or by charger if is an old revision not reworked or can be just the routing of the can bus cable charger/bms – they shoulf be routed far from the power bus battery cable, otherwise the battery cable may generate noise that affect the data TX/RX"
It means that I have to put the BMS nearby the controller?
  • stuuno
  • marce002
  • Heiwarsot
  • headsupcorporation
