Need help changing front fork oil and seal.
4 posts / 0 new
Hall9000
I was wondering , if the only option available to put on the vectrix was the fork seal from vectrixparts.¿Is there any cheaper alternative?.Regarding the oil , viscosity and brand , ¿can anybody recommend me how many liters/cliters and with brand type?
Thank you community.
Bikemad
Bikemad's picture
Re: Need help changing front fork oil and seal.
Check out this thread for further information.
Alan
Hall9000
Sorry but you didn't answer my question.I'd had red the post you mentioned , but the only thing i can understand is the folowing:
"The specs of the VX-1 forkseals (info direct from the factory)
Fork Oil seal: inner 35mm - out47mm - th10
dust seal 35 - 47,4 - 46 -14 (not quite sure how to read that part.)"
But in the post they do not mention the oil , the brand , the quantity or even where to order the fork seals with those specs.
Anybody else has any clue?
Thank you.
Bikemad
Bikemad's picture
While it may not give the quantity or type of oil required, at least it mentions where the oil level should be:
- install new oil seal
- insert fork tube without spring
- push fully down the tube
- fill oil until level reach 10cm distance from top of tube
- press and pull few times tube for allow air to escape from hydraulic circuit
- refill until level reach 10cm distance from tube top
- pull all tube up
- install spring (part of spring with tighter spring coils must be placed down)
- close tube cap
- install new dust seal
A quick look on vectrixparts.com website produced this:
Information on the suspension fork of the VX-1.
Which fork oil comes in?:
 Original oil: Shell tellus s2v68
How much fork oil comes in here?
 135cc
Check out the Technical Data Sheet for more information.
Unfortunately, it doesn't mention whether the 135cc is for a single fork or a pair.
I have just had a quick look for 35mm x 47mm x 10mm seals on eBay and there seem to be several seals with the same measurements, but the vary in appearance.
If you have a fork seal to compare them against, there shouldn't be a problem finding suitable seals.
Alan
  • stuuno
  • marce002
  • Heiwarsot
  • headsupcorporation
