Intermittent Brake light?
1 reply [Last post]
Sunder
Hi all,
It's time for my roadworthy test again. Unfortunately it failed. Front fork is leaking, which is pretty straight forward, but he also said the brake lights were inconsistent. Sometimes they turn on when the brake levers are pulled. Sometimes they don't.
He reckons it's just a worn/dirty switch, but since Vectrixes are quite rare, he's not willing to hunt down parts etc. I'd have to do the service/repair myself.
1. Does anyone know if this is the most likely problem? I've seen some threads saying brake lights can flicker if you change the front light, but I don't know if it's the same issue, since it only seems to have happened recently, and I've had the LED conversion for a while now.
2. Does anyone know where I can get replacement parts or compatible parts if it ends up being the switch? I can't see anything on eBay or Vectrix Parts.
Thanks.
Re: Intermittent Brake light?
check faston plug wires to brake switch. If they're correctly plugged in, replace brake switches.
style="display:block"
data-ad-client="ca-pub-2401070691062219"
data-ad-slot="2079401426"
data-ad-format="auto">
  • Loker
  • supertwike
  • Martin_EV4
  • acsatue
  • 186kmps
Customize This
