Vectrix reports
63 replies [Last post]
User offline. Last seen 7 hours 16 min ago. Offline
Re: Vectrix reports - loose break light cable and stand
duca wrote:
It looks like the spring retaining pin is inserted by interference in the hole, am I correct?
Luigi
I am not sure what you mean with "interference".
The broken off pin looks as if the end inserted into the hole was melted, but the circumference is smooth and clean.
I thought the pin might hold with a bit of glue because it gets jammed by the perpendicular pull of the spring, but that proved to be wrong.
It turns into a projectile instead, watch your eyes....
Locktite might work better, but would still risk sudden failure at any moment.
The Technical Representative of Vectrix Australia told me he would send a new stand asap.
He also helped to diagnose the problem with the loose brake switch cable by phone.
Unfortunately I still cannot get a center stand from Vectrix Australia.
Does anyone here have a center stand on their Vectrix?
Mr. Mik
New place for: Vectrix reports
this thread is getting a bit long, therefore I will continue to post here:
http://visforvoltage.org/forum/3272-vectrix-real-world-testing-2-noise-levels
to keep it more manageable.
Mr. Mik
kevin smith's picture
User offline. Last seen 4 hours 12 min ago. Offline
Re: Vectrix Test Ride in the Real World at 40km/h
well done mik but noticed that you had done this range test with the main dip light on 35 watts verry wasfull bulb ehh ..
i try to knock off the bulb where ever i can as just use the led on vectrix there fine in england if ya a safe rider
+ think probbley get few more miles out of v ..???
There are currently 2 users and 229 guests online.
WWWATTS.NET aggregates electric vehicle related blogs and podcasts
