Controller bench testing
Here's how I'm testing my controller just for the benefit of anyone who needs to know how to do this. With a few small batteries, lots of jumper leads, a 120v light bulb, two rubber bands, and a potentiometer (0-5k, 0-10k, 0-15k, ect, will all work). I have a printout of the controller wiring diagram which really helps not to screw something up (not shown). Double check everything before energizing the main + or - to the wiring diagram, as it's easy enough to fry something.
This is only for a brush motor controller. I don't know how to bench test a brush-less motor controller.
LOL, that's almost exactly how I do it. Except I hook it up to the motor and put the light bulb in series with the batteries (if I'm not feeling lazy).
AFAIK, it's pretty much impossible (without specialized equipment) to test a brushless controller without a motor.
That looks like a logisystems controller, eh?
Anyway, I've tried setups like that and ended up vaporising the jumpers. But I don't remember what I was using as the dummy load. For some reason this morning I was pondering whether this could be done, so you're saying it's just as simple as having a resistor in place of the motor? e.g. such as a lightbulb.
How much was that controller? Their website is "under construction" and I can't find any details of their products online. Also, is it programmable in any way?
Yea. They made it for 48-72v, 1140 amps. Awesome deal for the price assuming it works for a while.
...so you're saying it's just as simple as having a resistor in place of the motor? e.g. such as a lightbulb.
I was told by Logisystems to use a light bulb. They insisted doing this instead of using a motor on the bench (probably due to safety issues). Energizing an unsecured etek can cause it to fly off the bench even at low voltages. A light bulb is so easy to use.
KZ750 Motorcycle Conversion
900 watt scooter
Pic from http://www.electricmotorbike.org/
