I figure its about time that I start putting my project out there. I was recently featured on Autobloggreen, and I guess I didn't think that many people were interested. Then I found this place, and ecomodder, as well as a few other sites... so there's interest.
My website is: http://www.evfr.net and there are plenty of pictures, and a blog or two a week since I started last year.
About the project:
The bike is a 1986 Honda VFR700F that I found in Florida for $400 with no title, in like new condition. Brand new tires, been stored for 10 years with $4270 miles on it. I got it shipped to Oregon for $675, and parted out the engine, exhaust and electrical and just about broke even. The bike was essentially free. The title was lost, but it checked out, so I found another frame for $150 and swapped it after engine removal.
I'm currently working with a company in Portland on building a very robust 600A 156V fully programmable series motor controller. Its in test right now, and we're finalizing the design. We've got a PDA communicating with it for my display. It will display MPH (tach input to controller), motor rpm, battery side voltage and current, motor side current and voltage. It will display each battery voltage in the future. We're also working on battery balancing and charging designs.
A couple months ago I found an Advanced DC K99-4007 motor on a surplus website, and bought 2 of them. They are equivalent to the ADC K91-4003. They max out at around 50 or so ftlbs or torque and 18hp. Its 56lbs and has plenty of thermal mass. max RPM is around 5500. Just need to machine the shaft for a keyway and shorten the shaft.
I also scored 12 18Ah batteries (will do series parallel to get 72V) from another EV Motorcycle guy. They're about 13lbs a piece, for about a 36Ah pack at 72V, and 54Ah at 48V. Still working on how I want to charge and balance them.
For now, I'm using a 48V GE Controller I got from some guys that I used to work with at GE in their GE Power division (I used to work on the control systems for wind power). They happened to be using something similar for blade pitch testing. They needed something DC in case of power loss so they could feather the blades. This was one of the extras, and was donated. They also threw in an Allbright SW190 contactor.
Just picked up a Vicor 200W 48V to 12V DC DC converter for my accessories/lights/contactor for $20... score.
So I've got batteries, DC-DC, motor, controller, contactor, rolling chassis. I need to fabricate the motor mount (the Portland guys are helping me), make a battery cage and some battery/motor cables. I'm trying to pick sprockets and think I'll go with a 4:1 ratio. Some guys with eteks/perm132 go 5:1 up to 7:1. Other guys with smaller ADC motors go anywhere from 3.5:1 to 4.5:1. My motor is larger with more power, so 4:1 should be just right. I'm changing from 530 chain (#50) to #40 chain to make it more quiet. Sprocketspecialists have sprockets for me for under $100, and surpluscenter.com has sprockets and nickel chain. I need to start looking for a charger for short term, we're working on distributed charging right now, and its being tested.
So thats about where I am. Comments, critiques appreciated.
p.s. don't tell the VFR guys that I dismantled the VFR before I finish
Travis Gintz
1986 eVFR
____________
Travis Gintz
1986 Honda VFR Conversion
www.evfr.net
Re: My Honda '86 VFR700F motorcycle conversion
Sounds great. Please tell me more about your controller and the PDA link. I'm using a Kelly controller and was planning to add a PDA front end for programming the Kelly and displaying the PakTrakr & GPS data. AFAIK, I don't think the Kelly provides any data acquisition capability - but I might be wrong there.
I'm doing a CB-750 conversion with a similar ADC motor and 84 volts worth of 75Ah batteries (yes, it looks like a freakin' tank - but what the heck it should be a fun tank!). You can check my blog out for more details if you're interested: http://visforvoltage.org/blog/jdh2550-1
The project was on hiatus over the winter (my garage isn't heated and I'm a wuss) I actually began work on it again yesterday. I'm playing around with mounting seven individual 2A chargers in the old tank, and I'd like to find a reasonably compact 84V DC power supply that can be set to the float voltage for this pack so I can do "string + bank charging" (as per Aerowhatt's suggestion on this forum).
I'm hoping mine will be on the road in the next couple of months. But knowing me you should probably double or triple that estimate!
Good luck!
------------Re: My Honda '86 VFR700F motorcycle conversion
The controller is by a company called Synkromotive. Its a new controller, in development right now. I'm getting the first prototype, most likely in the next few weeks actually.
I can configure it for what voltage I want, up to 156V. I might populate the board with 100V components to decrease my switching losses. Right now its running at 156V on the proto, and ~170V on the new board. There's minimal rining, and its looking good. Max current is around 800 or so, but its rated for 5-600A, nice little controller. I'll be using it in my MC for 72V and 4-500A MAX. Its got an ISOLATED com port. It is an isolated controller as well, unlike kelly. I'm not sure how they get away with not isolating. Its also got USB working, built in F/R contactor and main contactor controls, new version has a precharge resistor built in. No onboard logging now, but thats what the serial port is for via a handheld PDA.
------------____________
Travis Gintz
www.evfr.net
Are you using both motors? That reminds me of when I was talking to a tech at electricvehiclesusa, there like put two eteks on, or just stick a 9 inch motor on if you really want it to move.
From what I gather, your probably planning for a very high system voltage, with the 48v now just to get things moving? I'm guessing you probably want to run both motors at 144v+ eventually?
I recommend buying a few different drive sprockets to adjust the ratio. It's hard to figure the perfect ratio on paper, and may take some adjusting. Also, consider safety. For example: in El Ninja, John Bidwell recommends a push button type large disconnect, but I'd much prefer a cable routed from the clutch lever to a high-amp DC circuit breaker that can break 10,000 amps, and that's how I did it on my bike.
Good luck with the controller/battery balancers/charger design.
------------KZ750 Motorcycle Conversion
900 watt scooter
Pic from http://www.electricmotorbike.org/
I read some of your blog earlier and while Synkromotive has a web site it's just a picture of their business card. Your site and maybe elmoto.net are the only places I found with info on this company. Can you say if/when they'll come out of hiding? er.. that is, come out of R&D phase?
What I saw looked interesting.. in that I take it their battery management isn't just with standalone units (like the powercheq) but a system where there is a master controller telling the battery management pieces what to do. I think there is room for an improved battery management if so.
------------- David Herron, davidherron.com, 7gen.com, http://www.7gen.com/store
- EVT 4000, Charger bike (rebuilt), Vego 600sx (rebuilt), Electrified Electra Townie
- Lectra motorcycle
These motors are HUGE compared to the eteks... but if you look at pictures, there's not just one bike... I've got 2 of the same chassis... so I'll make 2 mount plates, and battery cages. One will be developed with Lead, then the lead will be removed and transferred to the other bike while I upgrade the nice bike to LiFePo. I'm sticking to a 72V system for now (72V motor), but might go 84 or 96, depending on the cost of LiFePo.
48V is just to get things moving, but since the proto is done, I might just throw the Synkromotive controller in there. The 48V controller was Free, so I figure, use it for test, then upgrade.
As far as sprockets, I bought 11, 12 and 13 tooth fronts, using stock rear for now to get her going, and some standard machine chain. I'll get motorcycle chain later, the sprockets and chain were cheap at surpluscenter.
For safety, I'm going to have the engine kill switch wired in series with the contactor driver so I can drop it out. I might also do some sort of BRB (big red button), but as long as I can kill the contactor, we're good to go. Very little risk of the tabs welding. Its a 250A double pole contactor, so I can put 250 through each pole, for 500A continuous. Way over what I need.
Travis Gintz
www.evfr.net
They're fairly new, within the last year. They don't have an available product yet, and I'm trying to convince them to put more info up, but its just 2 guys in a nice shop. One electrical, one mechanical working to get it out. They're in the final stages of test. I'll provide specs as I get them.
They're not in hiding per se, but unlike Kelly who puts out product before its fully tested, and with fairly low current ratings, they want a full fledged product that is fully tested to hit the ground running with minimal issues.
Expect to see something within a few months. I'm basically one of their test benches... and they're converying a Pickup as we speak.
Travis Gintz
www.evfr.net
Travis - I'll be very interested to hear how the Synkromotive controller works out for you, and to hear about the cost. The reason I went with Kelly is because as soon as you cross the 72V threshold choices of controllers plummets and prices sky rocket. Kelly seemed like a good price - of course if it fries itself then it will turn out to be a false economy - however, someone else on this forum (racermike39) seems to have had good experiences with them on his ATV conversion.
Any idea of the cost? Will they have different models for different types of motors (series, sepex, PM etc. brushed vs. brushless)? Does the controller allow you to monitor amps and volts in "real time"? At what frequency? Sorry to bug you with lots of questions - but at least this should arm you with ammo to get the guys to tell us more on the website
Or they could come over here and start posting.
All the best, John H.
for the high voltage 156V 600A controller, its going to be priced just below the curtis 144V. Its fully isolated, and has higher current carrying capability than curtis and kelly. It will be competetive with other controllers while offering more flexibility.
They've got a working 150A AC Controller that works on converted Alternators, as well as the mars (although noisy because its trap wave). Its on the back burner until the power side is finished on the dc side (since they're similar). They've also got a 250-300A 156V AC version they're working on too. I expect they will be able to sell a lower cost lower voltage controller for their DC, but first thing first... fill a niche that needs to be filled.
The controller spits out voltage, amps on battery AND motor side, as well as temperatures and tach feedback from the motor (if equipped). Its got a 1s update, but thats just for starters. It can be adjusted to 10 times a sec or more for logging of faults... at 1s, you can't see voltage or current spikes before a fault. We're trying to figure out a sweet spot.
Travis Gintz
www.evfr.net
Sounds great. Certainly better than a Kelly - but quite a few more bucks (I can't remember the prices but I know that the curtis was significantly more than the Kelly). However, one of the things that put me off the curtis was the lack of programmability (so I was paying more money but had to pay even more if I wanted to program it). Will this controller allow me to program amp output limits? Low voltage cut off? And throttle curve on the input side (like the AXE)? I'm guessing yes to all of those (aside from maybe the last one?)
One nice thing to add if they want to make it a good option for professional converters is a way to either lockout programming or keep some form of NV record of programming events. In other words if I set max amp output conservatively to allow for things like a max current draw so that I can offer a warranty on the batteries I'd like to know if the user overrode those values (and hammered the batteries).
Feel free to stop answering these pesky questions - every time you tell me something I think of something else to ask
Just one more question - can I have fries with that?
Seriously, everything you've said so far makes it sound like a good choice for my "next" project (and only because I've already bought the Kelly).
All the best.
its a fully programmable controller. if you need other programmability, I'm sure they'd work something out with you. If you have a wishlist, put it here, its not hard to add if we know what people are requesting.
amp limit is adjustable, low voltage cutoff is adjustable, no throttle curve YET, but thats a good idea I can pass on to them.
The thing I notice about curtis, logisystems, is that they're not programmable. Alltrax is, but they don't offer the high current, high voltage models. Curtis does, but its not programmable, and the kelly is offering something but they don't derate, so they say 600A, thats more like 150A continuous. Its programmable, but I haven't hear alot of people get one in a project yet.
no promises on the final adjustability, but its pretty slick at this point. The lockout for programming is a nice option.
Travis Gintz
www.evfr.net
Any information about how well alternators perform as motors? Any data on efficiency, power output, useful RPM range? I asked this question about a day ago here.
If using an alternator as motor is a good idea, I'll build myself a sinewave controller.
well, they've got controllers working in gocarts, and one on a little minibike. With larger alternators you can get quite a bit out of them, but they require some reworking.
I'll see if I can get some info for you, he's got it somewhere.
Travis Gintz
www.evfr.net
I'm also interested in the reworking needed besides junking the existing regulator/diodes and bringing out the 3 phase leads and 2 rotor-leads. Also, I wonder what the optimum drive waveform is. I assume sinewave, but it might as wel be a trapezoid.
Thanks in advance!
And good luck with the VFR conversion. I'm curious what it brings you.
well, alot of the alternators out there actually have armature windings and slip rings.. and it has something to do with that. The waveform we use is a trap wave and it works just fine. On the mars, its loud (like the kelly) because they don't like Trap waves.
I'm getting some cable (2 and 3 Gauge wire) and terminals and hopefully set up the system on the bench this weekend. I'll keep people posted.
Talked to the Logisystems guy (Jim) and he was very interested in my bike and said If i needed anything to call him again...Great guy. They're doing some great stuff.
Travis Gintz
www.evfr.net
What's the breaking current capability? What's the voltage divided by the high-power system resistance? Mine is 72v/(.054 ohms), or 1333 amps. If the controller fails closed than my contactor can only break 1,200 amps, so at this point I'm holding my brakes and hoping the fuse blows. Does it blow fast enough? I hope so.
How much torque would your series motor produce in a controller failed closed? The torque equation appears to be T = K * I^1.5. Checking the torque curve for the K91-4003 and working backwards, at 300 amps the motor produces about 44 ft lbs of torque. This would equate to K=.008468 for ft lbs torque.
On the torque graph, the voltage is listed as 75v - .03I, and assuming .03 ohms is the motor terminal resistance (assuming they matched it for easy calculation with a .03 ohm power source), and add in some resistance for the batteries and wire, than your system resistance might be about .065 ohms. Meaning from stall and a controller failure, 1100 amps will flow. The contactor might break this, hopefully.
T = .008468 * 1100^1.5 = 309 ft lbs! At a 4:1 reduction, that's 1236 ft lbs at the wheel! Hopefully the breaks can hold, or at least enough for the current to stay high so the fuse blows. And hopefully you aren't already in oncoming traffic. In an old T/D golf cart my Dad ownes with a series motor, it didn't have any resistance in the system if the pedal was pushed down completely. The torque was amazing. You could spin out when starting, and it was just a 36v system with a 2hp rated motor.
And, this is while your trying to push the kill switch, so you can't hold the front break and your off.
Check this out: KillaCycle Shot to miniVan! & near killed Himself.
I wouldn't use anything but a 10,000 amp disconnect, and have it connected to the clutch lever cable so it can be pulled while holding both breaks, in a panic in about .2 seconds. I'll send you one for free if you want.
900 watt scooter
Andrew - you don't have to send me one for free - but can you let me know where you got your disconnect? I'm already planning on setting one up connected to the clutch lever as you did (stole the idea from reading your project page
Thanks.
well, sure, if you've got an extra I'll give you some money for shipping....
Looking at my contactor, It can break 1000A @80V, but My dad works at GE, and used these in some Wind Power (pitch control is done with a series motor), and they've broken more than that.
I've still got the clutch, thats a good idea... or I can hook it to the choke cable. Engine kill switch as first, and the disconnect as second.
Thanks for the tips, I'm more worried about just getting 48V working and tested mechanically right now... and as you know, constant improvement after that.
I'm also considering getting a sepex motor, selling the K99 (k91) motor, and putting in the 72V sepex GE controller.
Travis Gintz
www.evfr.net
I bought a box of them on ebay a while back. I can send you both one. I've also got control of my disconnect (Albright SW200-505) set up as my kill switch on my handlebars, but I won't mess with it in an emergency. Its just a good way to energize/de-energize the bike on the fly without having to switch the disconnect (which would shut off the aux system). It's a good safety feature, because I can denergize the bike easily while I need to open a garage door or something. A simple twist of the throttle on accident and the bike would go flying!
Regen would be really nice, if the GE controller can do that. It doesn't add weight, and can increase range, something you can't do with more lead.
900 watt scooter
btw can the K99 be run separately excited?
900 watt scooter
nope, its 30A to the field on the GE Sepex controller, but the field on the series needs to match the armature.
But yeah, its a lightweight, 400A 72V sepex controller with contactor controls, regen, RS232, programmability... and a watertight case. It was also free. ~6-700 for a sepex motor from electricmotorsport... but then i'd have 2 motors...
anyone interested in the k99?
Travis Gintz
www.evfr.net
frodus, I was informed that a circuit breaker is not a reliable manual disconnect. Sorry for the misinformation. It appears that a circuit breaker may remain closed even if it is manually activated. I'm changing my setup to use the main contactor as the emergency disconnect. I'm going to try and use the lowest rated fuse that won't blow just in case the contactor fails to break the current in an emergency.
I contacted the EV source and their opinion is that the SW200 Albright contactors are very proven in the ev community for breaking very high current.
900 watt scooter
well, I've got a SW190, still 250A continuous, 500A 30% duty cycle... plus, its double pole if I want to split up my pack... But thanks for the help... I'll likely get it running first, and test it in the shop...
I'm still working on getting the welding and motor mount stuff setup... i'm only working a couple days a week, for a few hours at a time, so we'll see.
Travis Gintz
www.evfr.net
well, here's the motor mount:
www.evfr.net
We got the motor pretty much mounted, mounting the chain tonight so we can spin the rear wheel. Major milestone.
Also took some pictures of the Synkromotive shop, and some of the other EV's we've got there.
Travis Gintz
www.evfr.net
So, I updated my Blog (evfr.net and shot a video... here you go!
Travis Gintz
www.evfr.net
I got some more work done, we fabricated some battery trays, and should have them finished by next week. Then we can wire this bike up!
Click on the pic to read more:
Travis Gintz
www.evfr.net
Another little update:
Travis Gintz
www.evfr.net
So, she's actually running now. Click the pic below for the blog entry and some pictures. I posted a video, but its dark. I'll get more tonight and throw it up on youtube. I'll do a walkaround as well. Looks like frankenbike, but it'l be cleaned up. We just wanted to get it together so we can begin testing.
Travis Gintz
www.evfr.net
I'm so jealous. But right now I don't want to insure a 4th vehicle, so i'll stick to the ebike. Definitely in my future though.
------------Be the pack leader.
36 volt sla schwinn trike
Its been a fun week!
Posted 6 new videos:
------------http://www.youtube.com/frodus17
____________
Travis Gintz
www.evfr.net
Congrats!
Nice work! I actually rode mine the other day. It's so funny how similar the bikes look! Mine has that Frankenstien look as well! It even sounds exactly the same! When I rode mine, I had the same "old" battery issues.
I am in the process of cleaning up the wiring, and finishing the charging curcuit.
I had to take a couple of weeks off of working on it to get the garden planted and my oldest son graduated, and a quick vacation to Cedar Point, Ohio for some thrashing on the roller coasters.
I am getting caught up on the loose ends, so I should be able to take another ride in a week or so.
Nice Work! Yours went faster and farther than mine on the intitial test ride! I had at least 2 bad batteries sagging to like 4 volts. So the ride was less than spectacular, but showed some great potential.
------------Thanks for posting the videos. I'll try and do the same soon.
Racermike
Congrats!
So what controller are you using? I'm using a custom, so I can't compare... but we can set the lower battery cutoff level and pullback level, so it can sorta save the bats. These bats suck... esp when you suck the amps from them, hence moving to diff batteries. I've only spent like 500 on this so far, so I can afford to get some newer batteries.
As far as range, we ESTIMATE 10 or more miles, but as far as measuring it, we haven't.... its just been around the block a ton of times.
The chain is noisy, once I get roller chain it should be better. I'm switching out sprockets eventually too, as the motor gets pretty warm (~200 deg F) due to all the stop and go acceleration around the blocks and stopping at stop signs.
Do you have some more pics of your bike? Any update?
Travis Gintz
www.evfr.net
I am using a KDH09600 controller. It also has adjustable low voltage, amperage, acceleration rate etc. Unfortunatly, when I changed out the bad batteries, I shorted out the wrench against the frame, and fried the controller. Kelly is warranteeing the controller. I was supposed to disconnect the B+ terminal before servicing the batteries. The controller fails quickly when you short the B- to the frame. Another humbling set back.
Kelly has been great every step of the way.
I am using a 13/54 gear ratio. What are(were) you using? I bought a roller o ring chain. They say it will get quieter after a few miles.
I will try and provide an update with pics soon. While the contrller is out for repair, I am trying to get all the unfinished things done so I can install the new controller and ride.
One thing I need help with, is getting the brake switch interupt to work, the side stand interupt, and the thumb switch on the throttle hand to kill the contactor. I bought a contactor with a 72V coil, so I am thinking I need another relay or solenoid to run the switch at 12 volts instead of 72 volts. I may just buy another contactor, but I don't want to spend any more money right now. I installed the Pak-Traker last night. That is a really cool device!
One of the big things I need to do is re-do the gauge cluster. I am not using anything factory from it accept for the temp gauge, side stand light and nuetral light. Once that is done, all the body work can go on to stay.
That's it for now.
------------Racermike
That's it for now.
wow, that fried the controller? I guess thats one reason to avoid kelly, their controllers are non isolated... ouch.
Ratio right now is 11/44 so its 4:1 Ratio... but I'll likely go with more like a 5 or 6:1 just for acceleration without sucking the amps out of the bats. I don't need top speed, not just yet. I didn't know what length of chain i needed, so i got some cheap roller non-o-ring chain for 20 bucks for 10ft surplus.
Yeah, you'd need to find a relay with 72VDC contacts. I don't know why you bought a contactor with 72V coils.... what was the rational for that? I'd see if kelly or whoever can exchange it.
Why aren't you using the gauge cluster Speedo? Is it digital or something? I'm using mine for now, and we might build a circuit to have the RPM gauge be Amps and drive it off the controller
Keep the stock look. We're going to use Temp for motor temp.
Travis Gintz
www.evfr.net
I didn't know they were not isolated either. Now I do! The instructions give a very suttle warning about that, but it needs to be in big red letters.
I don't know what I was thinking. Part of the learning curve.
My speedo was driven by a sensor in the transmission. I am mounting the Pak-Traker where the tach was. I am using a cycle computer for MPH, time & distance. I am also using the temp gauge for motor temp. It will have the stock look with DRO's for the 2 instruments.
Jesus Freak
Racermike
oops
HAHA, ooops, hit reply once too many ?
thats cool, haven't used other displays/monitors yet.... tonight we're going to try and feed the Current and Temperature to the temp and tach via some "extra" outputs on my controller.
Last night, Ives got some Data Logging in place within the controller, so whenever it faults, it saves, so you can actually go back and look WHY it shut off. We only had a couple shutoffs, nothing was hot, I think the bats were just low. We need to get some other data logging in place as well.
Went to a Local Dorkbot meeting (dorkbotpdx.org) and brought the bike. It was a very popular item, had a group of about 15 people around the bike all asking questions, commenting...
Jake (Who built Rezistor) came over early in the evening... and I gladly shared some of the spotlight... It was cool having 2 2-wheeled vehicles there. The Bar we went to for the meetup, actually let us "park" the bikes inside next to some tables. Its a huge bar, with garage doors, so its all open anyway.
Travis Gintz
www.evfr.net
So last night, I dropped by Synkromotive to help Ives with some testing. We tried logging with the DataQ again, and it it kept failing, no matter what setting we used. Nothing seemed to help. We unhooked it, and I’m going to contact Customer Service. We need something to compare our measured values to.
We spent the rest of the evening getting the Old Tachometer (originally fed off the engine spark), to display the current on the motor side. Its pretty cool, as you give it gas, it displays current at a 50A per 1000rpm resolution. So 200A is 4krpm. I’ll likely print something to display actual A, but its great for testing. Its just a PWM signal to the original Tach line. I’m totally cool with keeping the stock look, infact, I’m HOPING to keep as much of a stock look as possible. Now I need to order a PB-6 to keep my original throttle, order a EV200 contactor and get the lights working.
David Boyd got the bike up to 60mph… wow! It was fresh off the pack, and pulled 300A or so up to 30mph, and then it started to drop… at 55mph, it was roughly half of that. Better gearing should help this, as less torque is needed. We’ll keep gearing what it is for now because we’re testing something new every day. I thought it felt kind of like a 250cc, but David said it actually feels more like a 500cc. I think the batteries are waking up a little too, so switching to new ones in the future, with higher current draw is definately going to help. This controller rocks!
I got a jacket the other day, and am going to pick up a Helmet this weekend. Insurance won’t be that hard (My agent has been really cool about helping me). Registering it should be ok, but I’ll have to have someone make sure they see it doesn’t have an exhaust/was converted to electric so I can be excluded from DEQ. I’m also going to get a Motorcycle instruction permit… and keep my riding limited to daytime, with a friend. Just need to take the Knowledge test.
Travis Gintz
www.evfr.net
So, I decided to work my butt off this last weekend, and prepare the electric motorcycle for its first official public apearance. the OEVA was sponsoring an EV Awareness day downtown Portland on Saturday. I put everything together, cleaned it up, and went down there. Had a blast. It was one of the more popular vehicles there, because it was the only motorcycle, and the only electric sportbike that I know of in this area!
Read the blog article for details and some pictures!
Just thought everyone would like to see the finished bike. Still have to get it registered and get the lights working, but thats pretty easy stuff. Thanks everyone for the support, its been a long time coming, but the payoff has been great.
Travis Gintz
www.evfr.net
Congradulations! The bike looks showroom new....top notch workmanship. What kind of range did you end up with?
15-20 right now, but rather than new SLA's, I'm holding out for some Lifepo, looking at places to get it right now.
Not bad, acceleration is nice.
Travis Gintz
www.evfr.net
Nice job Frodus! The bike looks sweeeeet! It must have been great hanging out at the EV day. I look forward to riding to a car cruise or the ice cream shop, to see how many pick up on the fact the there is NO EXAUST PIPE!
Your bike looks completely stock. I just think that is so cool. One thing I reeeealy tried to do was maintain the stock look. I was really turned off by some of the bikes I studied in the EV album that had this huge box hanging under the bike.
I'm sure you will agree, after going through fitting all those batts in under the factory body work, why most people don't. That was painful, but I'm glad I was able to do it. It was worth it.
Thanks for the nice comments about my bike. I TOTALLY agree about the "brotherhood" of electric motorcycle builders working together. I hope to post a "lessons learned" blog soon. That should be helpful to others.
I look forward to more updates. Let's try and get some pictures of the places we have ridden to.
My batteries are even worse that yours. A couple of batts sagg big time when I go for a handful of throttle. My range is a little shorter. I am planning on picking up my new load of lead July 26th.
I am selling off some stuff to finance the batts.
Now we need to harrass JDH to stop playing with the "pasta jar of death", and get working on his CB 750!
Thanks dude, It wasn't just me, There's been a couple guys helping out with the welding. It was a blast at the EV day... tons of people were interested. Some thought it was a normal bike. Lots of people scoffed at the range, but for used bats, I'm ok with it
LiFePo this Fall will be good. Since I'm working with Synkromotive, I may be able to get bats as an OEM, and not as a hobbyist.
Dude, the first time we both ride it in public its going to be nuts. Did you get yours insured yet? Any luck?
Yeah, I didn't want to ruin the VFR, its a classic 80's bike, and I've already done enough damage removing the Vfour. Plus, I don't want people staring at it because it looks funny, but because they can't hear me.
I completely agree. All the painful fitting, measuring and engineering put into the battery frame and motor mount was WELL worth it. We kept our fairings
Looks better than tons of the cruisers and Ninja's that have battery cages sticking out just so they can fit their lead batteries in.
Thanks for the nice comments about my bike. I TOTALLY agree about the "brotherhood" of electric motorcycle builders working together. I hope to post a "lessons learned" blog soon. That should be helpful to others. I look forward to more updates. Let's try and get some pictures of the places we have ridden to.
Thanks for the comments on MY bike! We're all pioneers in electric sportbikes. Choppers have been done and look unprofessional. Some sportbikes have been done, but lose the lower fairings. We're going for the sport bike look AND sport bike performance. Go get a blog at Wordpress. I can host some pictures on my website if you need. Wordpress is a good blog software, and has lots of "skins" and customized features.
Taking pics of where we've been seems like a great Idea. I want to get a tank mount for my camera (or build one), so I can take some video. We took it out last night @50mph with fairings on. Bats were sagging a little.
I'm considering selling some stuff to finance lifepo as well. I've got a go-kart that I want to get rid of, and a whole bike chassis that we can convert and sell. What lead are you going with? What Ah batteries?
JDH, stop messin around
get to work!
[update on progress]
My friend Jim came and took some video of the bike riding around with full fairings. We both rode it and filmed. He'll cut the video this week, and I'll post to youtube ASAP.
We took the bike apart last night and are going to be modifying the motor mount due to clearance issues, add a motor support and clean things up.
We also lowered the battery cage a tiny bit due to frame clearance issues. The front batteries were hitting the frame a little bit. We're also installing battery hold downs, and painting the frame. We're not going to go all out on this frame or the motor mount, since we'll be "transplanting" the guts of this one to the other bike eventually. We got lots of ideas on motor mounting and will be remaking another mount, as well as a new battery cage for the lifepo. We don't know if it'l be 72V or 144V yet, all depends on what batteries I get. If I go 144V, I only need 20-30Ah or so. If I go 72V I'd like to do 60Ah.
Right now, while Loni is doing the battery cage, I'll be soldering the boards for my charging system. We got them in last week, and I'm going to be putting them together. There is once module for each battery to monitor and charge cells individually. The front end of the charging system is ~700W, so it'l charge the motorcycle just fine in ~4 hours (~2500Wh pack right now). The charging system for LifePo will be completely different.
We've got to work on how to fit the charging system inside the frame. There's still lots of room, so I'm not too concerned.
Also still need to get the Aux battery and DC-DC converter integrated, as well as the lighting (got some White LED's for turn signals and brake lights). It'l be another month or two of 1 or 2 days a week until she's finished, but she'll be LEGAL!
Travis Gintz
www.evfr.net
Here's a video that my friend Jim and I shot earlier this week. We have all the fairings on it, and pretty much have the motor mount and battery pack design nailed. We'll be cleaning up the wiring, making some small changes to the mounts, and upgrading the rear sprocket to a 60tooth (ordered 7-18-08).
Right now, I'm working on the custom charging system that will be installed as well as the 12V aux system for lighting.
Real nice shot at the beginning and end of Jim hitting 50mph.
http://www.youtube.com/watch?v=nOtyY5kIw2g
Travis Gintz
www.evfr.net
Nice job with the video! I enjoyed the walk around. Hey! was that a STOP sign Jim blew through? :>)
------------I will try to follow suit with the video. Right now I am stealing the 100 Ah batts from the electric tractor, and I will try it today with a VERY STRONG 100 Ah 48V battery pack. I figured this would be better than parking it until I can afford the new batteries. I just want to ride this thing! It should still go 45 MPH or so. Plenty fast enough for my commute to work on secondary roads. Plus the range should be excellent.
Man that bike looks (and sounds) GREAT!
BTW, I REALY LIKE the TACHAMPMETER! (I own the trade name (TACHAMPMETER) just incase you try to market that thing) ;>)
Racermike
Utterly awesome! I bet you can pull some Gs with the low-end torque.
I can't wait to see this bike with a deck of LiPos!
------------Working on a Piaggio Boxer (mo-ped) EV conversion: http://visforvoltage.org/blog/nasukaren
Cool! What kind of iterface for the tach? Is it just a milliamp meter? Or pulse? I would like to do this on my Ninja, only may be a problem with the regen going negitive.
Nice build...I love the "current/tach"!! Will the Synkromotive controller offer any regen? Don't touch your 144v rails--yikes! Hate to drop a wrench in that one!
Jeff K.
haha, yeah, we were making sure that traffic was stopped or clear before we waved him through.
Good luck on the bats, I can't wait to see yours in action!
tachampmeter... thats great.
I'm calling it the Synkrometer.
Travis Gintz
www.evfr.net
You can't do regen on series wound motors (at least not easily). It requires a different controller, that doesn't exist in the EV market yet. If you want regen in a bike, go with sepex, or a small AC system.
right now we're 72V, but 144 in a couple weeks. I think we'll install a disconnect between 72V packs to lessen the risk.
Travis Gintz
www.evfr.net
The interface is through the controller, just for testing. It uses the Dash light output, and is a pulse. Its the original tach, just hooked up a pulse signal and drove it via the controller. Programmed the controller to output current. We're going to switch to Watts.
Travis Gintz
www.evfr.net
Is the battery box meant to be a quick disconnect? e.g. could you set up a business renting and exchanging battery packs?
- Lectra motorcycle
we've tossed that idea around so we could pop a pack out. Only issue is connection losses and heating of those connections. I'd rather unbolt the + and - and drop the pack to decrease those losses.
We may play with some Anderson connections
Travis Gintz
www.evfr.net
