Electric powered PWC aka Yamaha Waverunner WR500
Buckeroo Bob's picture
I have an original Yamaha Waverunner WR500 which I want to donate to the University of Louisville rowing team to use as a coaching boat when they practice on a restricted lake that does not allow gas powered watercraft of any kind. I was thinking that the U of L Engineering Dept. might be able to convert the Waverunner to electric. Has anyone else done something like this? Thanks for any info.
Re: Electric powered PWC aka Yamaha Waverunner WR500
Hi Bob,
Great to hear from you, how's the electric banana running?
The only electric conversions I have ever seen for water have some version of a trolling motor or a small gas motor with an electric motor in place of the gas engine. I am not sure how you could get an electric motor to turn the impeller fast enough to get the jet ski to move very well. Of course that doesn't mean it can't be done. I think it is a very interesting project you'll have to let us know how it works out. Hope you can get some pictures of the internal workings.
Chas S.
Moderator Captain
 Type of Bike    Battery   Amp  Motor  Internal Hub Range Top Speed
or Trike Voltage  Hours  Watts  Transmission   Miles   Kilometers   MPH   KPH
Merida 1 36 Lead (AGM) 12 400 4-Speed 18 29 23 37
Adult Trike 36 Lead (AGM) 24 350 3-Speed 30 48 14 23
Merida 2 36 (5P 12S A123) 11.5 400 7-speed 30 48 30 48
Thanks for a reply. The "Electrical Banana" is out and about now that warmer weather has arrived...sporadically here in the Bluegrass...and working flawlessly! This electric craft would only need to move at slow speeds up to 10-12 knots. Part of their efforts would be to modify the pump/impeller parameters. It would be used by a rowing coach to monitor the women's crew as they practice on a small lake. I'll call the Speed Engineering School at The U of Louisville and see if they would like a project that would benefit the University.
frodus's picture
there was a guy that had one for sale on evforum
http://www.evforum.net/forums/showthread.php?t=162
other than that, I don't know of any..., you'd have to seal it really well.
____________
Travis Gintz
1986 Honda VFR Conversion
www.evfr.net
Thanks for the tip. I've emailed the guy and hopefully he still has it. Sounds like what the coaches need.
what RPM does a typical impeller run at? There are some high speed motors out there in RC-land which are both cheap AND high speed/power
