Desulfator
I am a new Z20 owner and I have set up bank charging per recommendations in these forums. it is working like a charm. One concern I have is that in the dropping of the Soneil string charger, desulfation action is lost. anyone know of an applicable battery desulfator (60 volts nominal) that would work with the Z bikes?
You might be able to get some help on the following forum http://www.fieldlines.com/. There are lot knowledgable folks to give good hint on electrical or electronic issues. lt does't hurt to try. Wish this helps.
