Electric Trike
Hi All.Am changing from a belt drive to chain drive.belt drive ratio is 11/1,chain ratio 4.2/1,will this work.john
Re: Electric Trike
Short answer: NO
If your trike only goes about 5 to 8 MPH with the belt drive then it might work but the ratio with the chain will give you almost double the speed and cut your range drastically. If your trike already goes 15 to 20 MPH the motor may not have enough power to move the trike on a small hill with the new ratio.
If you could give us more information, motor, battery pack size, current speed, and weight I might be able to give you a better answer.
Moderator Captain
 Type of Bike    Battery   Amp  Motor  Internal Hub Range Top Speed
or Trike Voltage  Hours  Watts  Transmission   Miles   Kilometers   MPH   KPH
Merida 1 36 Lead (AGM) 12 400 4-Speed 18 29 23 37
Adult Trike 36 Lead (AGM) 24 350 3-Speed 30 48 14 23
Merida 2 36 (5P 12S A123) 11.5 400 7-speed 30 48 30 48
