Los Angeles Vectrix Rider - LADWP EV discount rate question
3 posts / 0 new
electric_boogie
electric_boogie's picture
Hi there everyone,
I wanted to ask if any Los Angeles DWP customer that owns a Vectrix is taking advantage of the LADWP's EV discount rate program. Under the EV discount rate program, you have 3 choices and I have no clue as to what is the difference between choice 1 vs choice 2. What is the PROS and CONS of choice 1 and choice 2? Any input regarding this is much appreciated. Thank you.
I've copy and paste the info directly from LADWP / EV discount rate section (please see below):
5. Meter and Discount Information
*Please select one of the following:
choice 1: I want a time-of-use meter for my entire residence to replace my existing meter and add the electric vehicle discount rate.
choice 2: I want a separate time-of-use meter in addition to my existing meter to serve just the circuit that supplies power to an electric vehicle charger and the electric vehicle discount rate.
choice 3: I already have a time-of-use meter for my residence. I want the electric vehicle discount rate.
pchilds
pchilds's picture
Re: Los Angeles Vectrix Rider - LADWP EV discount rate question
You would want #1 if your daytime use is low (your daytime use rate will probably be higher than you are paying without TOU.) Use #2 if your daytime use is high and you charge at night (thus getting the best rate for your EV charging.)
Philip
Philip
2011 Nissan Leaf SL
electric_boogie
Thanks Philip for your help. Cheers!
Steve
Dump the Pump!
