My Bionx Bike
This is the complete Staton gear and chain two cycle engine drive kit with the NuVinci hub.It has the Bionx PL350 system on the front wheel.The lights are from Jet Lites Starfire Dual Beam W/ 5 Way Smart Switch.The bike frame is from Redline. It’s a Monocog 26in large frame. It was a single speed bike.I have it on you tube if you want to check it out.
| Attachment | Size |
| P1010751.JPG | 94.05 KB |
| P1010756.JPG | 71.42 KB |
| P1010764.JPG | 76.06 KB |
| P1010815.JPG | 72.81 KB |
Gammeray36,
I have been thinking of getting a NuVinci hub. Can you tell me how it works, do you like it? How does it perform? Can you shift while the motor is driving the bike? And anything you do or do not like about the hub.
Thanks a lot,
Grandpa Chas S.
Just turn the shifter inch worm flat on flat ground or going up hills turn up.It works great for me.
I have to let go of the throttle when shifing
Raymond Kimmell
