DC-to-DC 36v/48v to 5v/6v/12v for Accessories (Sirius Sat)
I have a Wilderness Energy BL 36 converted mountain bike. I would like to power a Sirius Satellite Radio receiver, mini amplified speakers, and some LED lights off of my 36v SLA batteries. The Sirius receiver takes in 5v 1.5A. My mini speakers take 4 AA batteries, so 6v. I'm sure I can find LED lights running at 5v or 6v. I think all of this should be able to run on 5v or 6v. I have a lighter-socket 12v to 5v DC-to-DC that came with the Sirius receiver so it can plug into a car's 12v which I can use. At some point I might upgrade my bike to 48v. So I am looking for a DC-to-DC converter that will handle 36v or 48v input, and output either 5v, 6v or 12v. Any reliable suppliers for such a converter?
- Brendan
Re: DC-to-DC 36v/48v to 5v/6v/12v for Accessories (Sirius Sat)
You can also run the speakers off the 5v, so you will need only 1 DC-DC converter.
DC-DC converters are not cheap, so you might want to reconsider this solution.
Just run the radio,speakers and lights off rechargable Ni-mh AA batteries, and carry spare cells in your pack.
For low amps like your application, 5v/6v voltage regulars are cheap and readily available for $1-2 dollars.
But input voltages as high as 48v are less available.
One way to get around this is to get 3 voltage regulators for each of the 12v batteries, and each regulator will take the 12 volt input and output 5/6 volts.
For $0.35, input at 35v max, Output current to 0.5A, Output voltage of 5v
http://www.goldmine-elec-products.com/prodinfo.asp?number=G13017
data sheet: http://www.st.com/stonline/products/literature/ds/2143/l7805c.pdf (look at the table for L7805)
For 6volts, get the 7806:
http://www.goldmine-elec-products.com/prodinfo.asp?number=A10483
For higher amps(claimed 3amps), use something like this:
http://www.goldmine-elec-products.com/prodinfo.asp?number=G15674
I don't want a separate battery for accessories. I am willing to pay for the convenience of a single plug-in to recharge at night. I also don't want to tap the individual 12v batteries.
I have ordered one of these http://www.dimensionengineering.com/VHVBEC.htm, but I don't fully understand how to wire it. Any advice?
Model: VHVBEC
Specifications: Input voltage: 9V to 60V (3s-14s lithium, up to 40 cell NiMH)
Output current: 2.5A (~6 standard servos, 4 digital)
Weight: 17g/.6oz (including wires)
Universal connector fits all receivers
nasukaren's picture
What a great BEC and a good find. I'm not sure why you're having problems wiring it. You'd just want to tap a 48V powerline and feed it into he +/- feeds on the left side and use the receiver power on the right side for your 5V equipment.
Just remember that red is + and black is - and you should be just fine. Just don't wire it backwards!
Your local RC hobby store will have the appropriate connectors (prewired) if you don't trust your soldering skills.
Karen
p.s. I just bought this one: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250270816138
on ebay. It only went up to 40V but it's only about $15 w/ shipping. Since I plan on running my moped at 28.8V, 36V, or 38.4V (i.e., not above 40V), I should be OK.
Working on a Piaggio Boxer (mo-ped) EV conversion: http://visforvoltage.org/blog/nasukaren
slbaker's picture
Hi Karen,
Can you send me the schematic for the LM2576HVT-12-ND down-converter?
I have a 48V bicycle project and I would like to run some 12V accessories.
You can see a picture of my bike project here Smiling
http://picasaweb.google.com/scott.l.baker/LongBikeProject#
Regards,
Scott
slbaker's picture
Here's a schematic for a very simple 20V-to-60V DC input to 12V DC output.
All the parts are available at digikey.com and the
parts cost is less than $10 (not counting the circuit board).
I may decide to make a circuit board if I can find some spare time Eye-wink
This same circuit can be used to make a 5V DC output regulator by just
changing the LM2576HV-12 to an LM2576HV-5 and a 6V regulator can be made
by adding a single resistor to the regulator's feedback path of the
5V regulator circuit.
http://mysite.verizon.net/sierracircuit/Free-Stuff/DC-DC-12V/schematic.pdf
Regards,
Scott
slbaker,
I was wondering about some additional specs. What is the max current at the 12v output? How many watts will this DC to DC converter handle?
Grandpa Chas S.
Moderator Captain
 Type of Bike    Battery   Amp  Motor  Internal Hub Range Top Speed
or Trike Voltage  Hours  Watts  Transmission   Miles   Kilometers   MPH   KPH
Merida 1 36 Lead (AGM) 12 400 4-Speed 18 29 23 37
Adult Trike 36 Lead (AGM) 24 350 3-Speed 30 48 14 23
Merida 2 36 (5P 12S A123) 11.5 400 7-speed 30 48 30 48
slbaker's picture
The LM2576HV-12 switching regulator is rated at 3A, but the coil that I
chose is rated at 2.5A continuous current. Even so, that's 30W.
I have not built one of these yet, so I don't know how hot
the coil or regulator would get when running continuous high current.
The LM2576HV's TO220-5 case allows for a heat sink if needed.
