- Forums
- V Forum
- Handbooks
- EV DownLoad Library
- Building E-Bikes
- Building Small E-Scooters
- Catalog of (known) commercial electric vehicles
- Controllers
- Electrical Circuits Basics
- Electric Bicycles
- Electric Motorcycles
- Electric Scooters
- Electric Vehicle Resources
- EV Accessories
- EV Batteries
- EV Motors
- EV Resource Links
- Legal
- Regenerative Braking
- Recent
Adjusting wheel diameter + system freeze problem
Submitted by brace on Tue, 08/19/2008 - 23:47.
Hi.
I traveled 500 km so far with my Bionx bike and I am very satisified with it. I have 2 issues:
1) I set the wheel size to 2199 (700c wheel, as described in the user manual). Anyway it looks like the distance I ride is overestimated in the odometer (and therefore the speed). I made a check on a 13.4 km road. I know that that particular road is 13.4 km long, by measuring it with my car and also by using google earth to calculate the distance. Both cases 13.4 km (so I would say it is 13.3 - 13.5 km). When riding the bike (I made the road 2 times, in both directions) I always have the same result: 14.4 km. So it looks like the Bionx overestimates. I also measured my wheel. And with a a measurement I had 218 cm, quite consistent with the 219.9 cm that I inputed in the Bionx console. So assuming my wheel is 2190 mm I should the the following:
Inputed wheel size = (13.4 * 2190) / 14.4 = 2038 mm ? (so 2038 instead of 2199)
I think I should, anyway I'd like to know if anyone has found the same problem. I say problem since the wheel circumference is ok, but anyway I have "higher distances".
Since the speed affects the speed limiter too, I'd gain some km/h and still being legal.
Please correct me if I am wrong.
2) Twice I had this problem: while pedaling suddenly the display moved to a "freeze" status and the kit didn't work anymore. No assistance, no response from the console, in one case the kit moved to "generation" mode so it was also difficult for me to push the bike. After several attempts I found the solution: disconnecting and reconnecting the console by temporarly unconnecting the the cable (about 15 cm from the console). That connection is quite "floating", I didn't secure it to the bike, so I feel like it is likely that hitting a stone with the wheel can make it disconnect.
Does anyone of you have the same problem? May be this can be caused from that connection to "disconnect"for a fraction of a second. In this case I could just use some tape to make it more secure, but I am not sure this is the way to go. I had this problem twice in 500 km, so it is quite difficult to reproduce.
Thanks.
- Login or register to post comments
- Email this Forum topic
Re: Adjusting wheel diameter + system freeze problem
The problem with measuring the wheel with no-load is that you will always over measure because the weight of you+bike+batteries tends to compress the wheel slightly on the road. So it's best to fine tune by doing what you are doing -- calibrating against a known distance. Play with the wheel diameter in mm. by subtracting small amounts until the odometer matches reality.
K
------------Working on a Piaggio Boxer (mo-ped) EV conversion: http://visforvoltage.org/blog/nasukaren
Thanks for the comment. I will for sure adjust the wheel size until the odometer behaves well.
In the meantime if someone can also comment on the "freeze" problem I'll be happier.
You don't mention the voltage of your system, so I'm not sure whether this is relevant. But I, and one other poster, have noted that the connection between the accelerator and the controller can loosen. This caused my setup to go into regen mode. It hasn't happened since I reconfigured the attachment of the cable to the handlebars.
I have the PL-350, so 36V.
I also had the regenmode inserted in one case, in the other no. Probably this is a random factor, since the disconnection brings the system in an unexpected state that can give random results.
Anyway since you also had the loosen connection, probably all I need to do is to fix this somehow. The reason why I left this loosen connection was in case of a bike accident, to avoid that the cables can be damaged. Anyway the likelihood that this happens is very low, while it is not impossible to have disconnections as I experienced.
Thanks.
