electric motorcycle project
Eh. I guess I happened to be in a frame of mind to think a smartass counter-quote would be clever. Sorry. I guess I could have left a note, but I'm really shy. :/
I do have a pair of ebikes, actually. There's a bit of info on them in the member vehicles section here, and detailed histories over on the Endless-Sphere. I call them the PackCycle and the S-Go.
Those build histories are pretty long, BTW (4 and 10 pages, respectively).
The PackCycle hasn't been used in a while (I think I killed a few of the batteries), and the S-Go got into a semi-bad crash which potatoe'd and split the join in the front rim and I've been working on a battery box ever since. I hope to have that back up very soon...
I believe you could, but the regen wouldn't actually do anything.
Regen works by boosting the BEMF from the motor higher than battery voltage, so they start charging. Without a magnetic field around it, an armature doesn't produce any BEMF, so it can't do regen. Since a series motor's rotor and stator are linked, you can't have just the field coils excited, so the rotor can't produce any BEMF.
JY -
I know Link, I'm friends with Link, and you aren't half the man or EVer that link is.
Poof.
K
Why are you wearing a helmet but your passenger isnt? You have the right to kill yourself, but not other people.
Eh? I've never taken any passengers on my bikes. I don't even have any way to mount the camera for on-board vids up yet...
Sprocket housing's looking good. Might have to use the same method if I ever get around to a go-kart.
The fastest ebike on the planet...
HI SPEED WARPAGE? This is why I would never put a bicycle wheel on a motorcycle Popeye.
LOL
You know, I still haven't figured out why the chain falls off like that (causing me to look down at it and then run into another biker turning the corner, for those who don't know the story). I will, however, be using the middle sprocket from now on.
Er...I think he was referring to his kid there, Karen, not me...
The case on this motor is 5/16" thick. Can I electrically mig weld on the outside of it without hurting the motor? I really dont want to have to take it apart to weld on the case. I have used a set of ICE motorcycle motor mounts that already have the same arc as the motor case. I suppose that welding on the case will cause some electromagnetic quantum forcefield that will fry the motor?
Hmm...hard to say. I wouldn't try it, as the heat might fry a bit of the insulation on the windings. Taking a motor apart generally isn't very hard, anyway, and since there aren't any powerful magnets in a series, they come apart even easier than others.
Most people have the mount designed so that the motor bolts to it, though. Easier to take on/off or upgrade.
Did you build that 30MPH (deathride) skateboard yet? You think that AC unit hurt? Ride a 30MPH skateboard and you will find out what real pain is. Tighten up the trucks up all way (if it has them). Please dont do it though til I finish with this CR, I need your help to finish it.
LOL, sort of. I bumped up the G1 to 48V once, and it should have been doing around 25mph. Trucks were wobbly as hell (they weren't good to begin with) and the wheels were visibly worn and hot after a short ride. And I did have a minor wipe out that left me looking stupid but unscathed.
The A/C didn't hurt at all, actually. But I think I have a phobia of open wounds...on me, in particular...
Only be a few things can cause it:
Sprockets are not aligned with each other
Sprocket is not spinning true or is worn
^Dial indicator, laser level, or even a straight edge can be used to check.
Chain tension is too loose, too tight, or chain is bad
Could be, but I'd never had any problems with it before. It would have been jamming up the derailleur if I was.
Sprocket isn't really true, but not by very much. I've had other bikes with worse sprockets not have problems. It's kinda worn, but no where near needing replacing.
Tensioner was good, and the chain was brand new.
All I can think of is maybe it got caught on my pants...? Tonight, on Unsolved Mysteries. :/
I could also put the front derailleur back on and jam it in place, I suppose. Might do that if the problem persists.
What kind of batteries are these?
PowerSonic PS-12180, IIRC. They're okay. I get them mostly because I have a local source, so I don't have to pay for shipping.
Scrapped motor? Don't throw it away! Gimme gimme gimme! J/k but not really. :P
LOL, that motor weighs as much as I do. You so crazy. XD
By "visibly worn" I mean it looked like someone had run them against a miter saw. I really think they would be worn to the hubs within 25 miles if I were to do that all the time.
Probably right about the derailleur, but I never heard it click against the chain when I had it adjusted properly. Oh well. I can (a) avoid pants that would catch on the chain, (b) put it back on and jam it in place, (c) use the middle gear instead, or (d) not pedal.
I like a combination of (c) and (d), myself. :D
You can have the motor, but the cool custom totally tricked out phat stupid dope (Old english... Bitchen) patent pending housing end will cost $6,000,000... cash, no receipt
Woo! Well, I know a guy who SUPPOSEDLY has a golf cart, and I offered him like $150 for the motor and controller like a year ago. He said yes and then backed out later. However, I saw him earlier today and his excuse was that I never gave him money (his original excuse was that he decided to keep it and get it running again). So, I'm thinking maybe I'll offer him $300 for the motor, controller, pot box (accelerator pedal), wires, and transmission. Assuming he's really got a golf cart.
Chains and other moving parts at high speeds have a tendency to "harmonically" vibrate at the right frequency (speed). Even perfectly aligned chains and sprockets in perfect condition can experience harmonic excitation at a certain point if they aren't perfectly balanced. The longer the chain the sooner it will happen and the more warpage of the chain will occur. A dampner may be necessary to stablize the chain and stop the vibration. And, wear those freaky pencil-legged skater pants so you will look aesthetically appealling (referencing your painted wire problem ) right before you wipe out.
Given the gearing of the sprockets and that I only really pedal at relatively low speeds, I doubt it was harmonic resonance. Might just be that Wal-Mart bike gears suck. Oh well.
If I'm thinking of the right pants, then no. :P The painted wires were replaced with black 10AWG, and have just recently been replaced again with 12AWG silver-clad teflon wire to suit the brushless Golden Motor.
By definition, would that make it a motorcycle with cyclical foot pegs?
Eh...Technically, it's already a moped because it goes faster than 20, but not over 30. Now, after I rig up a boost pack to get bursts of 40+mph, THEN it's technically a motorcycle with cyclical foot pegs.
Gotta keep an eye out for the popo. :)
I think it is time to let this thread die and disappear into the abyss called the archives. Stay tuned for eleCtRic 250: Phase two
Mouhahahaha }:)
Go ahead Popeye, only 19 phase remaining, if we didn't counting the phase 1A (small motor version) and the phase 1B (Golf cart motor version)! :D
Dont make me break out a can of Spinach
Please can you define clearly your gender role, if your are Olive. With the correct gender roles, i think this statement is mommy can fix everything!.
I have to much fun kidding you, and i'm just too curious to know if your able to build an Electric motocross one day or another with link's help before you reach the phase 20... }:)
Brutus
Sounds so interesting.I only heard electric bikes
- « first
- ‹ previous
- 1
- 2
- 3
- 4
Nice guys finish last.
Bad day at school? What does that have to do with leaving a note? A pat on the back, a hand shake and a thank you are more valuable than anything. You dont have any idea yet what hell it is to lose your wallet and have to cancel and replace everything in it. Some things are irreplacable. It took me two years to straighten everything out after losing my wallet and some lowlife went crazy with my ID and credit cards. I guess you thought that I meant he might give you a monetary reward? No. You might have made a friend. He might be someone who could change your life. At 16, while I was working in that little hotdog stand for $3.25 an hour (minimum wage) after school, I did a favor for one of my regular customers, not expecting anything in return. A week later I was night-managing his little gold mine fast food mexican restaurant, making 3 times what I was making to start and all the mexican food I wanted to eat. He did always complain that I ate too much of his profits/food. A few years later he opened several more of those little gold mines, and one of them was 1/2 mine. Maybe the guy who lost his wallet owns a scooter shop.
Its not just what you know, but it is also who you know.
BTW, You have never built an EV? You should! Maybe not a 96V 1,000A racing bike with $15,000 batteries yet. You should learn to ride before you sit on a rocket. My son has about 10 hours dirt practice on my XT350. Do you own one? You said,
My YiYun will handle 100V already.
If you do, tell me about it.
