Wilderness Energy BL-36 at 48V -- Any Advice?
4 replies [Last post]
engr_scotty's picture
I am considering a used, local BL-36 and would like to run it with a 48V ping battery. I've read about the BD 36 at 48V and it sounds like the LED charge indicator will not work, which is OK. I don't want this to be an engineering project, so do you see any other shortcomings for running a 48V Life (probably 12Ah) on the BL-36? Any mods to the controller necessary?
Scott
Re: Wilderness Energy BL-36 at 48V -- Any Advice?
I see no problem at all. Go for it!
rjarois's picture
scotty, just slap the pack on and ride....everything works normally....i have over 350miles on mine so far, no hick-ups...
review this link.... http://visforvoltage.org/forum/3697-bl36-enhancements-standard-system
dogman's picture
The only issue could be the sise of the battery. In my opinion the larger sise, like 20 ah is cheapest since it will get less stress on it in use. I don't think the max continuous specification is going to give the number of cycles that the 1c rate, of 1amp per amp hour will. The test is at 1c. If you have hills, then you will inevitably draw more than max continuous at some time. I know the price is high, but the idea is to not have to pay it again for many years. A few posters I have seen who complain about the pack losing capacity have invariably exceeded 1c in my opinion. Email Ping and order directly from him to get the best price.
Thanks!.. The 48V 12ah is tempting for 2 reasons: lower cost and weight. I do have rolling hills, so I am hoping this BL-36 (400W) will work in this environment. My test ride was on relatively flat ground with a 2y/old NiMH 36V battery, and it performed OK, going about 17mph on the flats.
One other question: I bought the bike/BL-36 minus the controller(15A) and batteries. I need a replacement controller for 48V. Any suggestions? /source links?
Your help is greatly appreciated!
Scotty
Short URL
Customize This
