This charger, soneil 3650 S, can be adjusted to a higher voltage to charge lifepo4 easily. Easy as pie if I did it. One this charger one pot has an adjusting screw on the top, located near the edge of the board near the charge indicator led. A tiny twist on the screw and a check with a voltmeter and I have a 47v charger instead of the 44.5 v sla setting. Apparently other soneils can also do this, but this one is easy since it only has one adjustable pot to look for.
Tweaking soneil 36v charger for lifepo4
Fri, 10/03/2008 - 13:32
#1
- Bengun
- Skyhawk 57
- wild4
- justinsmith07
- Juli76
