tires for EVT 4000
Hello,
I would like to improve handling of the scooter. Standard tires are 3"x10 and I would like to fit larger tires now. I know that the rear one should be something like 90x90 10 or 100x80 10 maximum and larger ones won't fit without scooter mods. I don't know what size to choose for the front wheel. I know that a very large front wheel will improve handling and braking a lot so I'm ready to fit something as huge as a Michelin Bopper. Does anyone know what is the largest tire I can fit on the front EVT wheel please ?
Thanks for help !
Hello,
how well do they behave on wet road ? Can you compare them to other known brands like Michelin S1 for instance ?
Jerome
Hello,
Jerome
Works fine in the wet, sorry haven´t tried any other tires for comparison, but a well known brand shouldn´t give you any problems.
Are they ME7 Teen ? Do you think that the larger 110/80 10 could fit at front ?
Sorry don´t understand "ME7 Teen"....I shouldn´t go for wider than these, but you can always measure the front fork, 11cm (4.33 inches) width, maybe they will fit.
Look at these tires: http://visforvoltage.org/forum/4819-upgrading-evt-168-motorcycle#comment-28531
Works beautifully both front and rear, and gives you much better handling.
Johnny
