I have a 350W Bionx Motor that I would like to use without their controller. I was originally under the impression that the motor connections would be the same as other brushless hub motors (3 power wires, and 5 sensor wires) with the exception of extra connections for the torque sensor. However I was surprised to see only 2 large power wires, and 6 smaller wires. I don't understand how a brushless motor can work with only 2 power wires, unless the speed controller is actually inside the motor. From the pictures I've seen of the controller inside the battery box, it appears to only be a battery management system, since I haven't seen any power mosfets for driving the motor. Is that correct? Does anyone know the pin out for the motor connectors? Has the motor been hacked to work with standard controllers (or without controllers if the speed controller is actually built in)?
Dan
Bionx Motor PL350 Connector Pin Out and Hacking
Tue, 12/30/2008 - 11:41
#1
- Bengun
- Skyhawk 57
- wild4
- justinsmith07
- Juli76
I can't help you with pinouts or other internal info, but the pictures I've seen show the mosfets inside the motor.
