Help debug my electric scooter problem: motor has no torque
starrychloe
Please help me debug my electric scooter problem. The motor (48V, 500W) has no torque, but will spin when off the ground. I don't know if it is the controller or the motor, or something else.
Motor continuity, disconnected: yes, .5 ohm
Voltage at battery/controller, connected, zero to full throttle, wheels blocked: 52-42 V
Voltage at motor/controller plug, connected, wheels blocked, full throttle: 3-4.5 V slowly increasing
Voltage at motor/controller plug, connected, free wheel, low to full throttle: 5 V - 17 V
Voltage at motor/controller plug, disconnected, low throttle to high: 52.5-52.1 V
Current at motor/controller plug, disconnected: about 6 A with quarter throttle (very brief test - was afraid)
The problem happened suddenly. The scooter gave out and did not seem to run. The motor makes a whining noise when it tries on the ground and the pitch goes up as the throttle goes up. It can barely push itself, but not with any weight on it. When the wheel is in the air, it can spin fast, and goes faster and faster over time slowly. Sometimes, intermittently, it will have full power/torque. Thanks!
LinkOfHyrule
LinkOfHyrule's picture
Re: Help debug my electric scooter problem: motor has no ...
Hmm...my wild guess? It's not the motor; something's slipping. Does it have any belts or gears?
check the controller to make sure the shunt resistor hasnt desoldered itself.
if the shunt resistance has increased, the controller motor side current limit will be significantly reduced, resulting in no torque, but no reduction in free-wheel speed or measured on resistance.
MOSFETmeltdown
MOSFETmeltdown's picture
Hmm...
"The problem happened suddenly..." and "Sometimes, intermittently, it will have full power/torque."
Loose connection?
colin9876
Bizarly I have exacly the same problem
I just bought a micro folding 180w rear hub bike from ebay.
Its supposed to be pedal start but only gives a teeny bit of power - not even enough to keep it going on the flat.
I just assumed it was bad batteries but the supplier says they r new
where is this shunt resistor - outside or inside the controller box?
the shunt resistor is almost always inside the controller.
it will either be on the battery input side, or the motor output side.
follow the big wires/traces, there should be component that looks like a resistor, or a bit of metal soldered across two thick traces.
  • stuuno
  • marce002
  • Heiwarsot
