I am building a 48v electric motorcycle with an alltrax controller and an Etek motor. I found an EV200 contactor but found it only has a 36v coil rating. What are the possible downsides to using this for a 48v system. I have the EV200AAANA and needed the EV200ADANA series. This is one of my planned cut off points, the other is going to be a side mounted mechanical switch between the motor and controller which will also enable me to program the controller without disconnecting any wires. Thank you
- Bengun
- Skyhawk 57
- wild4
- justinsmith07
- Juli76
