Green indicator light on controller
3 replies [Last post]
blairg
blairg's picture
What does the green indicator light on the controller indicate ?
dogman
dogman's picture
Re: Green indicator light on controller
Blinks various indicator codes. The steady blink is all is good. I am waiting to hear from a vendor what other blink cosdes indicate. No doubt one will be low voltage.
blairg
blairg's picture
Thanks Dogman...let us know what you find out
mrgarci1
From my WE documentation:
Red light = power (on/off)
Green light blink codes:
steady = all connections correct, no signal from throttle
No blink = motor is receiving throttle signal and power, motor should spin
Slow 6-blink pattern = hall effect circuit disconnect/broken wire
slow 8-blink pattern = batt voltage below 31.5v - RECHARGE! (their emphasis, not mine :) )
Slow double-blink = brake cut-off circuit is engaged
light blinks while motor is powered = trouble with the hall effects circuit
This came with my Hall sensor-less BL36, and also has the specs listed for a 50A controller, when mine is only a 25A, so this information may not be complete, accurate, or current - it's marked 2007. But it's a start!
style="display:block"
data-ad-client="ca-pub-2401070691062219"
data-ad-slot="2079401426"
data-ad-format="auto">
  • Loker
  • supertwike
  • Martin_EV4
  • acsatue
  • 186kmps
Customize This
