Tubes and tires for XB-600
8 posts / 0 new
electrogo
Last seen: 14 years 4 weeks ago
Does anybody know where to get quality tubes and tires for the XB-600? I got a flat today and had to walk this thing a couple of miles to get home. Captainslug got his new tires from bikebandit.com (90/90-12). Anyone else? Also, is there a good source out there for good tubes? I would like to avoid flats in the future.
Thanks.
win32forth
win32forth's picture
Re: Tubes and tires for XB-600
Two word: Green Slime
Stops everything but a blowout!
Tom
sixpax2k9
Found this also. Hard to find 16x3 tires. When needed I sure don't want the stock tire, too thin for the desert thorns in SW New Mexico.
http://www.motorcycle-superstore.com/5/32/404/5780/ITEM/Pirelli-ML-75-Rear-Moped-Tire.aspx
Happy scooting
JamesS
Looks like Bridgestone makes a tire we can use
http://mc.bridgestone.co.jp/en/products/hoop/b01.html
It's a B01 hoop. Here's their phone number 1-615-937-3442
www.BikeBandit.com has some cheng shins for $15 ea!
http://www.bikebandit.com/tires/c/a642336a4a8a634806
-Warren
Dave ; Tennessee
XB-600.
electrogo
Are the walls of these tires thicker than the stock tires?
clinton
electrogo
Where do you buy tubes for the XB-600? What size do I ask for?
Thanks.
clinton
Laurie
My 600w bike (not XB) uses a 3.00-10 tire and tube. I found some nice 4 ply Kenda tires at Powersport Superstore. They are much heavier than my OEM or my Cheng Shin 2 ply tires. Which of course makes them harder to get on the rim as well :(
bickyd1a
Use the tire protectent from Ride-on.com. It prevents leaks from a puncture instead of trying to patch them.
Safe scooting,
Bickyd
captainslug
captainslug's picture
90/90-12 tires fit, and any replacement tire you buy are going to be thicker than the paper-thin ones that come stock. Just wet the bead of the replacement tire when you put it on or you'll have a difficult time of it.
3.00-12 is the tube size, but you will want a tube with a 90-degree stem for the rear. I'd recommend a 90-degree stem for the front too since they're easier to install on small rims.
If you want to replace them yourself I would also recommend getting a set of three tire irons. You can find videos on youtube that show how to use them.
