new Veloteq. I want more speed "HOW ???"
4 posts / 0 new
chippawaguy
I have just purchased a Veloteq commuter 48 volt 500 watt brushless motor scooter. Here in Ontario it is limited to 32 kilometers an hour. Does anyone know or can help me on how to increase the speed. The rated power is 750 watts the specs are listed below, any help would be great. The dealer said there is a way of getting about 5 kilometers an hour more but he won't tell me unless I sign a wavier, does anyone else know how to do these bikes up. Thanks again Bill
Motor
Type Lube injection gear reduction BLDC motor
Rated Voltage 48V
Specified Output 500w
Highest Idle RPM 400rpm
Fixed torque/corresponding rotational speed- 22Nm/284rpm
Maximum torque/corresponding rotational speed- 64Nm/25rpm
Idle operation electric current 1.8A
Operating current 12A
Overload Protection 600V Circuit Breaker
Controller
Type Computer controlled switching and power regulation
Rated power 750W
Power Supply Unit
Batteries 48V/20Ah (4 x 12v/20AH Valve Regulated Absorbed Glass Mat)
Weight 62 lb
Charging Unit
Type Cord connected power supply; Class B, UL/cUL Listed
chippawaguy
Re: new Veloteq. I want more speed "HOW ???"
I should point out Im not too interested in range I go to work which is only about 1.8 kil from my house and maybe boot around town right now I get about 50 kil on a full charge but I want to go faster,thanks again for any help.
m3chen
If it is anything like the old 2007 Veloteq Commander Sho, there is a pair of red and white wires that connect to some sort of limiter. You probably only get maybe 3-4kmh more but it will drain your battery faster.
Art
There is a wire that hangs down in front of the rear shock on the left side there is a conection point,disconect them but the gear reduction motors suck for the speed increase maybe 2 or 3 kmh increase, the best motors for speed r the hubs where you could get a 9 or 10 kmh. I have talked to veloteq head quaters raged about the loss in speed a range they claim that the gear reduction goes up steeper hills. Piece of shit if you ask me.
