Voltage versus torque
7 posts / 0 new
jaustinmd
Need some basic informaton ... I have a 24v gearmotor that runs perfectly fine on 24 volts or 12 volts. Of course, at 12 volts, the motor speed is reduced. Two very basic questons have come to mind:
1) Is motor speed directly proportional to voltage - i.e., does the motor run half as fast at 12 volts versus 24?
2) Does reducing the voltage and speed reduce the torque, or does it remain relatively constant? I have always heard that "electric motors develop 100% of their torque instantly" ... it would seem that would have to be definitely independent of speed!
Regards,
John
Re: Voltage versus torque
Torque is proportional to motor side current:
Torque = motorside current * constant
Voltage = motorside current * resistance + rpm * constant (if the motor has a powered field, then the "constant" is variable with field current)
if operating with a controller, torque-speed relationship is the same (for the purposes of this discussion), its just the speed values halve if you halve the voltage.
Last seen: 1 year 2 weeks ago
Build Your Own Electric Vehicle has a lot of detailed information and formulas about this. The book is meant for building electric cars, and would be useful if you want deep understanding.
caspar21
simpler way to put it..
voltage - hp
amps - torque
magicsmoke
voltage - hp
amps - torque
nearly!
voltage - rpm
amps - torque
hp - (rpm X torque) / K ... constant depending on torque and rpm units
Rob
james joule
Hi, could you explain the K constant a little more please, cheers james
in metric, the equation is:
Power (w) = torque (Nm) * rpm /(120 * Pi)
in imperial (IIRC):
power (hp) = torque (Ft-lb) * rpm / 6350
im less sure on the imperial one, since i never use it, and the defintion for Hp is different depending on context.
