Insufficient Contiuous Current From A Lot Of Lithium Ion Battery Pack Manufacturers
4 replies [Last post]
Just trying to find a Lithium Ion pack capable of supporting a 400 to 600 amp controller 20 to 30 miles
Brushless hub motor at 72 volts.........oh wait........let me guess............sixty two hundred and forty three dallars
and three cents.............................Will that be cash or.........NEVER!
Anyone else in the same car as me?
Re: Insufficient Contiuous Current From A Lot Of Lithium ...
uh... can I talk to you about some lead batteries? ;-)
Actually let me suggest the headway batteries. Not sure but I think you could use a 100ah pack of headway cells to support that peak load. But if $643 is your budget you won't be able to afford any lithium anything, good or bad. Keep saving your pennies or else go with a lead pack.
- David Herron, Green Transportation Examiner, Green Transportation Info, The Long Tail Pipe, Torque News, electric race news, davidherron.com, 7gen.com, What is Reiki
- EVT 4000, Charger bike (rebuilt), Vego 600sx (rebuilt), Electrified Electra Townie
- Lectra motorcycle, 1971 Karmann Ghia
e-doggies's picture
$6243.03 Does that include tax?
OK, I'll play...
1) 600 Amp controller. Likely 600 Amp peak and 300 Amp continuous. So, we need 300 Amp Continuous batteries. Thunderskies are good for 3C continuous so you need 100Ah cell minimum.
2) 72V = 24 cells. 24 cells is actually 76.8V at rest, but pulling 3C you'll see voltage sag so we'll stick with 24.
3) 76.8V * 100Ah is 7.68kWh. You get 80% of that to play with which is 6.144 kWh. You want to do 30 miles - gives you a budget of 204.8 Wh per mile. That part's up to you - can you live with 200 Wh per mile?
100Ah * 24cells * $1.75 per Ah = $4200.
Add a BMS and a charger, let's say $5,000.
Shipping extra ;-)
Remember: " 'lectric for local. diesel for distance" - JTH, Amp Bros || "No Gas. No Worries." - JDH, CuMoCo || "Make Volts Not War" - anon.
$6243.03
heh.. shoulda read it a little more carefully. I withdraw may suggestion of a lead pack. Never mind.
Short URL
Customize This
