where are the fuses?
1 reply [Last post]
User offline. Last seen 29 weeks 3 days ago. Offline
Where can I find the fusebox on a Zapino?
Where can I buy replacement fuses?
djkees's picture
User offline. Last seen 4 weeks 4 days ago. Offline
Re: where are the fuses?
There are a couple fuses under the floor board. Lift up the rubber mat, and you should see a couple screws holding down a plastic cover. Remove the screws and use a flathead to pop off the cover. I believe these are standard automotive spade fuses that you should be able to buy just about anywhere. I'm not sure this is THE fusebox, but it may be the ones you're looking for.
If you are having a specific problem, list the symptoms and someone here might have more info.
There are currently 3 users and 215 guests online.
