Help with controller
3 replies [Last post]
User offline. Last seen 5 weeks 4 days ago. Offline
I found a Curtis 1205-117 pretty cheap. Will this controller work for an Etek Motor 12-48 VDC? I wish to put this into a KX 125 (or similar) frame. It has been confusing searching for a controller. Can anyone recommend a list of good ones to use? I don't want to spend big $$ of courseEtek
Re: Help with controller
Motor specs are;
20 HP Peak, 8 HP continuous
Voltage........................50 VDC
Max Nonload Current.....6 AMP
Max Nonload Speed........3600 RPM
MIN Nonload Speed.........3300 RPM
Min Speed at 160 Lbln.....3200 RPM
Max Current at 160 Lbln...150 AMPS
Shaft Size .......................7/8" Dia. 2-1/4" long
Voltage Constant: 72 RPM per volt
Torque Constant: 1.14 in lbs/Amp
Continuous Current: 300 A 30 Sec.
User offline. Last seen 5 hours 4 min ago. Offline
Sounds like you are on the right track. I have a number of Curtis and Curtis clones and when used on permanent magnet and series wound motors will work perfectly and for a long time. I made a Kawasaki KZ550 electric with a 2.5 HP series wound motor and the controller never got warm let alone hot. Every so often you see controller on eBay for way under $100.00 and make a good way to learn about Pulse Width Modulators or controllers. Test them using a light bulb and a 0-5 K pot or inductor if that is the type controller you have. Some use 5 volt input some use 5K - 0 ohms and other use 0 to 5K. Altrax controllers are RS-232 programmable.
Russell
jeGra Project
http://home.comcast.net/~russell239/
Rusty
Thanks for the response. Are you saying I can use a series controller with this motor? I have a couple of Curtis 1203 controllers but they are too light of duty for this motor. I also have a Curtis 1207 for a wound-field motor.
There are currently 1 user and 113 guests online.
Online users
WWWATTS.NET aggregates electric vehicle related blogs and podcasts
