Anybody done a pedaless crystalyte setup?
3 replies [Last post]
User offline. Last seen 18 weeks 2 days ago. Offline
Working on my ground design but need to purchase motor kit before beginning the welding of the frames rear section so I can set up the disc brakes.
wheelie's picture
User offline. Last seen 8 weeks 16 hours ago. Offline
Re: Anybody done a pedaless crystalyte setup?
S.Badger...
Yes - using pedal free settup on my trike... link to image of wheels - http://visforvoltage.org/forum/5645-dual-x5039s
10Inch rims - 5302 motors. dual Kelly controls.
Using motorcycle discs on these motors due to the weight/speed of the bike. It was necessary to machine an adapter to mount the discs to the standard mounting holes on the motor casing. The brakes I'm using are a left/right set from a racing go-kart - hydraulic twin piston jobbies - using left-hand brake lever to opperate.
The 'standard' discs seem a bit too light weight for any serious usage.
Hey thanks for the note I will check out your trike
Hry thanks for the note I will check out your trike
There are currently 6 users and 186 guests online.
