Chain size explanation (aka difference between #40 and 420)
No replies
Jacob
I have been looking for an explanation of the two different chain sizes, the two vs three digit, and found it.
Here it is:
Chain size is in inches, the three digit number used to discribe the chain size is based on the "rule of eights". The first digit is for chain pitch. This is the distance between the pins. The second and third digits combine for roller width, with a decimal point inserted between the second and third digits.
For example, a 420 chain has a pitch of 4/8" = 1/2" (12.70mm) and a roller width of 2.0/8" = 1/4" (6.35mm).
A 525 chain (the size my bike uses) has a pitch of 5/8" (15.88mm) and a roller width of 2.5/8" (7.94mm).
A 530 chain has a pitch of 5/8" (15.88mm) and a roller width of 3.0/8" (9.52mm).
Now I feel better that anyone searching for "Chain size explanation" (including me) can find it for posterity. Thanks VifV!
style="display:block"
data-ad-client="ca-pub-2401070691062219"
data-ad-slot="2079401426"
data-ad-format="auto">
The Electric Vehicle and the Burden of History
Electric and Hybrid Cars: A History
Build Your Own Electric Vehicle You need this book if you want to build your own EV
Internal Combustion: How Corporations and Governments Addicted the World to Oil and Derailed the Alternatives
The Transition Companion: Making Your Community More Resilient in Uncertain Times
The Party's Over: Oil, War and the Fate of Industrial Societies
  • dnug2000
  • SimonH
  • james Moon
  • tcj
  • vx18650
Customize This
