power cut out problem
1 post / 0 new
quicks2k
Hello I'm new here so big HI to everyone :) .
I have a power problem with my kit.
spec:
480w 48v brushless hub motor
48v lipo 10ah pack
when i apply even slight load on my bike the power cuts out and battery voltage reads around 2-3 volts. to get power back i need to disconnect the controller and connect again.
Ive changed the bms and changed the controller but the problem remains, downhill I can almost hit full throttle but on flat surface i get cut out after 1/3 of throttle and on hills even on less.
I've tested individual cells and they all read fine, battery fully charged read 56~ volts.
battery under load reads 45-48 volts and cutout then.
If anyone have any idea what could it be please tell me.
