A Typical Driver
No replies
weiku
The MAX232ID device which includes a capacitive voltage generator to supply EIA-232 voltage levels from a single 5-V supply is a dual
driver/receiver.Each of them converts EIA-232 inputs to 5-V TTL/CMOS levels.These receivers have a threshold of 1.3 V and a hysteresis of 0.5 V,which are both typical ,and can accept ±30-V inputs.
Features of the MAX232ID can be summarized as:(1)applications;(2)±30-V input levels;(3)two drivers and two receivers;(4)LinBiCMOSE
process technology;±30-V input levels;(5)low supply current is 8 mA Typical;(6)package options include plastic;(7)designed to be
interchangeable with maxim MAX232;(8)operates with single 5-V power supply; applications;(9)ESD protection exceeds 2000 V per MIL-STD-
883,method 3015;(10)meets or exceeds TIA/EIA-232-F and ITU recommendation V.28.
The absolute largest ratings of the MAX232ID are(1):the parameter is input voltage range,VI:receiver,the rating is ±30,the unit is V;
(2):the parameter is positive output supply voltage range,VS+,the rating is VCC –0.3 to 15,the unit is V;(3):the parameter is output
voltage range,VO:R1OUT,R2OUT,the rating is –0.3 to VCC+0.3,the unit is V;(4):the parameter is input voltage range,VI:driver,the rating
is –0.3 to VCC+0.3,the unit is V; (5):the parameter is input supply voltage range, VCC,the rating is -0.3 to 6,the unit is V;the
parameter is input voltage range,VI:receiver,the rating is ±30,the unit is V;(6):the parameter is output voltage
range,VO:T1OUT,T2OUT,the rating is VS––0.3 to VS++0.3,the unit is V;(7):the parameter is negative output supply voltage range,VS–,the rating is –0.3 to –15,the unit is Vthe parameter is output voltage range,VO:R1OUT,R2OUT,the rating is –0.3 to VCC+0.3,the unit is V;(8):the parameter is lead temperature 1,6 mm (1/16 inch) from case for 10 seconds,the rating is 260,the unit is ℃. (9):the parameter is storage temperature range,Tstg,the rating is –65 to 150,the unit is ℃;(10):the parameter is short-circuit duration:T1OUT,T2OUT,the rating is unlimited;the parameter is lead temperature 1,6 mm (1/16 inch) from case for 10 seconds,the rating is 260,the unit is ℃.
style="display:block"
data-ad-client="ca-pub-2401070691062219"
data-ad-slot="2079401426"
data-ad-format="auto">
The Party's Over: Oil, War and the Fate of Industrial Societies
The End of Growth: Adapting to Our New Economic Reality
The Electric Vehicle and the Burden of History
Divorce Your Car! : Ending the Love Affair with the Automobile
Two Billion Cars: Driving Toward Sustainability
  • dnug2000
  • SimonH
  • james Moon
  • tcj
  • vx18650
Customize This
