Can anyone help me to hook up a new 24Volt 20Amp brushed controller ? There are 6 connectors tied to the blackbox : 2 Andersons ( one for battery and one for motor ) , 1 female four pin ( for thumb throttle with batt indicator ), 1 five pin male ( with 4 pins actually but wider than the four pin type , dunno what is for ) , 1 three pin male ( dunno what is for ) , 1 three pin female ( I'm not sure , maybe it's for ebrakes ? ) . I have only the controller with thumb throttle ,a new motor , nothing else . I tried it with the new brushed motor , if I connect only the throttle it doesn't work . Do i need to use ebrakes ? ( or jump/short the proper connector ?) . The motor is ok , works fine when connected directly to 24V battery .
- Skyhawk 57
- wild4
- justinsmith07
- Juli76
- xovacharging
Normally the brake function on controllers works as 'make connection to cut power', i.e. if u dont have brakes connected it should work.
Can u post up a photo?
The box has an indicator LED that will come on as soon as I connect 24 Volts. The throttle will also have the red and green LEDs on . I suspect that the controller is for "pedelec" bikes , maybe one of the connectors is for pedal assist input .
tryin to stay alive
