48V, 20ah Ping batteries
Greetings everyone. In one of my earlier posts I mentioned that I might be buying Ping batteries, and now that has happened. I had the shop install the batts and I've had a couple of days testing the new ride. And... quite a big difference. The hill that I climb every work day is one that I normally take a run at- it's a steep winding slope- but the new pings will actually acellerate with little strain. I haven't taken any readings from the cycle analyst, but am planning to do so in this topic page as time goes along. Total cost, to me, was about $790 Canadian, all in. The shop had a few difficulties installing, as the shape of the duct taped unit didn't quite fit the existing box, and they had to shim the box a bit, but everything is well now. The battery weight has gone from about 60lbs to just over 20lbs, and this has made a difference in handling, reponse, speed and as mentioned, acelleration. I actually decided to buy the Pings after bionicjay reported his pings catching fire! Sounds crazy, but when Ping sent him another pack, I was impressed that he did the right thing. Happy trails everyone.
I have a pair of Ping batteries from - I forget how many years ago - that are still going strong.
Overall today I rode about 37km (23mi) and used 12.5AH. It's slightly above par compared to the SLA's, but there are fairly significant differences- the bike is both more responsive with increased power and speed. I also noticed that there was little 'drag' on the last steep hill I climb, one that had I used the old batteries, would have stopped me about 3/4 of the way up. If I'm reading LifePo4 graph's properly, there is little power draw down over amp hours used. I forgot to check the voltage at the beginning and end of the ride, however I did notice that at no time did the bike draw more than 32 amps, and this included a steep 8 percent grade that took a few minutes to climb. On my next ride, I do want to do better speed checks, rather than subjective and also monitor the voltage over time. Happy trails.
We’ve all heard that a million monkeys banging on a million typewriters will eventually reproduce the entire works of Shakespeare. Now, thanks to the Internet, we know this is not true.
