Battery Dealer or Distributor
Batteryspace
Submitted by reikiman on Mon, 10/29/2012 - 14:17Sells a wide variety of batteries for a wide variety of gizmos. They do carry lead-acid and NiMH and Lithium-ion batteries suitable for electric bicycles or even motorcycles.
High 5 Scooters
Submitted by rodman on Tue, 06/14/2011 - 20:12
High 5 Scooters offers a wide variety of electric bicycles, mopeds, and mobility scooters. Inexpensive bikes with sealed lead acid batteries or more expensive, but highly affordable and priced right, bikes powered by the latest Lithium Ion battery technology. Fast shipping and knowledgeable customer service.
High 5 Scooters operates a highly accessible and easy to use web store at www.high5scooters.com.
High 5 Scooters is located in Florida. We ship nationwide. We also have a showroom from which fully assembled scooters can be viewed and purchased. Full repair service is also available at our Florida dealership. Fast nationwide shipping is performed direct to your residence from warehouses located on or near the U.S. west coast.
High 5 Scooters has earned a reputation with both its customers and with product manufacturers for outstanding customer service. We answer or return your call the same day, provide our own expert support and ensure that you receive the highest level of support from the product manufacturer. We immediately go to bat for you if you ever run into any difficulty with obtaining what you need from the manufacturer, be it warranty support or simply getting an answer to a technical question. As needed, we follow-up to ensure that any warranty parts are shipped to you in an expedited manner.
Electric Vehicle Mall
Submitted by rodman on Tue, 06/14/2011 - 19:51
Established in 2008, Electric Vehicle Mall sells green 100% electric bicycles, mopeds, standup scooters and motorcycles. Just plug them in at night! No gas, no oil changes, no maintenance. By using solar power to charge your electric bike or scooter, you can have a zero carbon footprint! Economical gas scooters also available. Fast shipping! We stand behind and service every product we sell.
Electric Vehicle Mall provides an sophisticated shopping experience with lots of product information and pictures at www.ElectricVehicleMall.com
Electric Vehicle Mall is located in Clearwater, Florida. However, all shipping is performed directly from warehouses located strategically around the United States. This saves on shipping costs, which we pass on to you in the form of lower prices, and also allows fast delivery to anywhere in the continental U.S.!
Electric Vehicle Mall offers full repair services on every model it sells.
The importance and value of earnest, timely and expert CUSTOMER SERVICE by a reputable dealer should never be underestimated. Electric Vehicle Mall has earned a reputation with both its customers and with our product manufacturers for outstanding customer service. We answer or return your call the same day (usually within 30 minutes), provide our own expert support and ensure that you receive the highest level of support from the product manufacturer. We immediately go to bat for you if you ever run into any difficulty with obtaining what you need from the manufacturer, be it warranty support or simply getting an answer to a technical question. As needed, we follow-up to ensure that any warranty parts are shipped to you in an expedited manner. You are in the safest of hands when you purchase a product from Electric Vehicle Mall.
smart battery testing system
Submitted by judy366 on Tue, 03/29/2011 - 00:27Neware Co.,Ltd located in Shenzhen,China. We primarily manufactures a complete range of battery testing systems for all the rechargeble battery as Li-ion, LiFePO4, Ni-MH,Ni-Cd,Lithium polymer battery
NEWARE is our registered brand. Neware testers are widely applied in battery testing fields such as electrode materials research,battery,large-scale battery formation,capability grading,battery internal resistance test,electrical vehicle battery test,etc…
We can customize the tester as customer's requirement from voltage 5V~500V,current 1mA~1000A
sigle cell tester pic:
data analyzing software interface
battery pack tester(meet large volate and current test need)
Equipment Comprehensive Performance
1.1Hardware Features
a,According to the international standard design, each channel of the system has an independent constant-current source and constant-voltage source
b,The internal electrical power supply uses the high efficiency switching power supply, the energy conservation effect is remarkable, each power tube has the independent protection circuit, guarantees the Equipment works with safety and reliability.
c,Measure adopts four wire method, decrease contact error, increase measure precision.
d,Each channel is independent;
e,With high efficient cooling system, Equipment can work 24 hours with full load.
f,Hardware adopts double loop control,can change from constant current to constant voltage without pinnacle,protect battery.
1.2Software Features
a,Each channel can program and test independently, after any “stop”, (including power failure) the work step has “continue” function, prevents the current data loss
b,Upper machine is compatible, can suit different versions of lower machine, and has the friendly man-machine interaction contact surface, ease of operation.
c,High speed data acquisition, catches the change detail of voltage and current precisely (16bit AD), with journal function.Formidable data and curve processing function; perfect report form function, supports four kind of report form types and sorts of report formats:
d,Formidable data and curve processing function; perfect report form function, supports four kind of report form types and sorts of report formats:
e,Sees namely the obtained report form: The data obviously derives.
f,Conventional report form: Derives the entire NDA data file
g,Lamination report form: The circulation level, the work step level, the record level data derives separately
h,Definition report form: The user can define and derives the template of the report form
i,The data and the curve may derive to EXCEL, TXT, can be edited and processed
Need more informaiton,visit our website www.neware.com.cn
or mail me:judy366@gmail.com (TEL:86-15814472201)
skype:wxc366
Scooteretti
Submitted by Scooteretti on Tue, 02/22/2011 - 15:50- Battery Dealer or Distributor
- Electric Bicycle Customization or Repair
- Electric Bicycle Dealer
- Electric Bicycle Distributor or Manufacturer
- Electric Bicycle Parts or Kits
- Electric Motorcycle Parts
- Electric Scooter Dealer
- Electric Scooter Distributor or Manufacturer
- Electric Scooter Parts
- Electric Scooter Repair or Customization
Scooteretti is Ottawa's largest and premier electric scooter / e-bike wholesaler and retailer. With a huge inventory of in stock scooters, parts and accessories. We are proud and passionate about introducing the next generation of exciting, stylish, eco-friendly electric scooters and electric bikes. With uncompromising quality, reliability and safety built into each and every one of our scooters. Come see for yourself what we're all about.
Ev Components sales sale
Submitted by markgresens@gma... on Mon, 01/31/2011 - 10:46I have a huge sale on Hipower 100AH lifepo4 batteries if anyone is interested please email me markgresens@gmail.com i am selling them for less than 100 dollars a cell so less than 1.00 dollars an Ah
Electric Motor Depot
Submitted by reikiman on Mon, 01/03/2011 - 19:44Their "mission is to help decrease our dependency on carbon emitting fuels and increase the availability of the products that make this possible. Our custom Electric Conversion Kits are assembled specifically for small personal electric vehicles such as Motorcycles, ATV’s, Go Karts, Boats, etc. We bundle top quality electric vehicle parts in order to save you the time and hassle of piecing together random parts from several retailers. So help us become a bit more Eco friendly and have a great time doing it!"
They are based in Sacramento CA.
LiFeTech Energy
Submitted by LiFeTech Energy on Fri, 09/10/2010 - 02:05LiFeTech Energy is a major manufacturer of high performance, premium quality LiFePO4 batteries and associated products. Information on LiFeTech products can be found by visiting our website at www.lifetechlithium.com
LiFeTech Energy is an official licensee of Phostech Hydro-Quebec, Canada.
Current EV Tech
Submitted by reikiman on Fri, 09/03/2010 - 15:17Based in Olympia WA, they sell a full range of parts and gizmos for electric vehicle conversion. This includes lithium-ion batteries, battery management, chargers, motors, controllers, various accessories, cabling, etc.
FalconEV
Submitted by proton on Mon, 08/23/2010 - 17:56It's all about the battery
custom made here in USA
with LiPo or LiFePo4 cells
