I used David Dugas' firmware at https://www.dropbox.com/s/velaqoqi1x24rbj/VX1%20Full%20Package%20SW%20March%202022.zip?dl=0 to reprogram my VX1 ICM, MC, and Charger after swapping in 36s Chevy Volt cells.
I'm now trying to use VX1 Configurator R2.exe to reconfigure the charger limits. It let me change the MC voltage limits and the number of battery cells, but it won't let me change the Max Cell Voltage (it's 0.000 volts right now). I tried the comma versus dot thing mentioned at https://visforvoltage.org/forum/14235-problem-dougas-engeneering-firmware but that doesn't change anything.
Can someone point me in the right direction?
Thanks...
What charger are you using? Sorry I cant help directly as am new to this and about to reflash a Vectrix I picked up last week. The charger I have is EVPS (Runke) V3.0 AD152151-SF. The sticker on the charger says max DC is 155V
I am using the ESD charger.
